ok so I ran out of firewood and the stove got cold- wasn’t planning on getting more since it’s end of April here in Northwestern NJ and it “should “ be warm by now.
I finally gave in and bought another chord of seasoned wood because it hasn’t warmed up and our unreliable boiler also decided to stop working a few weeks ago.
What I noticed since trying to get the stove going again:
PLENTY of smoke- not just coming out the door while open but also pouring out of the wall inlet where my pipe goes in and up. This wasn’t happening a week ago or so when I was still burning up the last of my previous chord.
The smoke from the wall inlet only occurs while the stove door is open- as soon as I close the stove door the smoke from the wall inlet also stops - BUT so does my fire, even with the stoves air damper open. This inlet was sealed up with chimney cement when I installed the stove and piping but that stuff expands out and have noticed a gap. Like I said though, it wasn’t a problem until now.
The problem is, the fire only blazes up hot when the door is open- I can’t get the stove warm enough to actually provide heat or get it into a decent range on the stove thermometer because I have to close the door because of the really terrible smoke. So the chimney pipe also doesn’t really warm up and nothing gets into the “sweet” range on the thermometer.
CHIMNEY TOP / stove pipe top, outside is smoking as it should be. I can’t help but think the fire isn’t getting enough air “flow through” or a vacuum past the fire from the air inlet on the stove- through the chimney thanks to a blockage in the chimney.
The chimney piping itself comes off the stove up about a foot then back and toward the right through two elbows- then about 2 feet into the chimney pipe and another elbow upwards ( which used to be a clean out, but the actual clean out capability is in an inaccessible spot).
I wonder if stuff settled down the chimney piping into the bottom when the pipes got cold about a week ago. That kinda makes sense, but I’m no expert. But if it’s blocked- why would smoke be coming out the top?
I’ve been burning every day since October and cleared the chimney only once prior to the season. During the season I’ve burned creosote logs about once a month.
