I have been giving a lot of thought about lining my Heatilator chimney. Safety and the height of the roof puts me off. I also have been thinking of running a separate Class A in another part of the house and leaving the Heatilator fireplace alone. So here is option 2. I have a spot in my kitchen that may work. I live in a two story home. My garage ceilings are very high, I'd say around 15 feet or so. I would like to set the stove in the kitchen come off the top of the stove go up about 6 feet than a elbow ( I have 10 foot ceilings in the home) 3 feet though the wall (with thimble) with heavy duty steel stove pipe into the garage. From there connect (still going with steel stove pipe) a tee at a 45 degree angle giving it pitch. Than run it (8 feet) to a 45 degree elbow than hook that up to a straight 14 feet Class A chimney out the roof.
Concerns: 1) Is it safe to run a Wood stove pipe in the garage like this? Of course I would follow all clearance factors.
2) Will this draft properly. If you count all the pipe from the top of the stove it's about 30 feet. But will the elbow, tee, 45 and the 45 degree pitch make this
a poor drafting flue?
3) Would this be up to "code"
If need be I could come out the back of the stove and run it to a tee tilted at a 45 degree angle to a 45 than up saving me a 90 elbow?? What's do you think. I'm I headed for problems with this 2nd option? Should I just line the Heatilator? I should also say that the Heailator flue is straight up about 25 feet. This 2nd option would be on the far side of my garage roof giving me better access and peace of mind by going with the Class A flue. Not sure. Opinions welcome
