im a first year burner with a jotal f400. had some issues in the beginning of the season more because i just didn't know what i was doing. after some good help on here i got my stove running pretty good. my wood was cut down and split in march of last year, so its far from perfect but it works and its all i have. the stove is attached to a double wall stove pipe then through the wall to double wall chimney and up. this is all brand new
i checked the clean out in the chimney and stovepipe in December and did a sweep out. had a little bit of junk in there but not bad.
last night before bed i loaded up a big load, it was kind of giving me crap like it always does. takes a while because of the darn wood. i heard some crackling at the 90 on the stovepipe and thought... oh crap....
i shut the stove down and took tin foil and blocked the hole under the stove to choke out any oxygen going up the pipe. few amber's were blowing out the top of the chimney but no visible flames. house smoke up pretty good.
about 10 minutes went by and everything calmed down. i took the smoldering logs out of the stove with my tongs and threw them in the snow. bout an hour later i pulled the stove pipe apart at the top and took a quick look with my flashlight. about 1/4-3/8 thick crap lined the 90 and the through pipe.
ugh what a nightmare.
my woodpile is up on pallets and the top is covered with tarps but, we have had tons of snow this year and no matter what i do, snow seems to find the wood. i have absolutely no other place to put the wood other then outside.
im assuming my half seasoned wood along with all the snow we have had in the last month and a half is what really caused this build up so quickly. the stove will not be run until i clean all of it out but now im mega nervous. should i just clean it out once a month as a safety ?
any suggestions would be a big help.
