We built our house last year and have a zero clearance fireplace with a metal flue that is about 30 feet tall with a chimney cap. Last year was our first to use our fireplace and we burned wood every night from about early November through early March. Then didn't use it again until end of October this year and have used it every night since. It hasn't never been cleaned. Mix of well seasoned wood and greenish, but nothing that has seasoned less than 5 or 6 months.
So tonight we started the fire about 5 and I was going to go to bed about 1 burn stoked it up and put a fresh log on (cherry wood) and I noticed a strange smell and the fire seemed hotter than normal. Didn't think much of it. I stepped out to let the dog in and noticed glowing embers and ash raining down from my roof, so I ran over and looked up and the chimney cap was glowing organge and you could see the ash spilling out, I kind of panicked.
I ran and grabbed my extinguisher and put out the fire and got all of the embers out of the fireplace but it took a good 30-45 minutes before the chimney cap wasn't glowing and before I stopped seeing glowing ash come out of the top.
So did I just have a chimney fire? What would have caused this? I was told by the builder we needed to get the chimney swept every third year, and it had only been one and a half seasons of burning wood. Should I completely discontinue use of the fireplace? I plan on calling next week to have a chimney sweep done.
Temps tonight were in the single digits and there was a slight north wind of about 5 mph or so.
This is the first home I've ever had with a fireplace and maybe I shouldn't have listened to the builder and had it swept this year?
Anyways, just now settling down after all the commotion and was hoping for some insight/advice. Maybe this is something more common than I'm aware of.
Edit to add that I tried looking up the flue when the cap was glowing but I couldn't see anything. But the flue is only about 12 inches wide or so and the fireplace was still hot so I didn't get a great look. But there was nothing obvious that was wrong from inside, only reason I knew was because I stepped outside and saw the ash.
