I own a large brick Greek Revival home, built circa 1830. 35x45 footprint, peak of house is approximately 45' tall.
There are four existing chimneys that the previous owner used unlined, with green wood. Crumbling brick inside. I had one lined a few years ago and heated with wood as a bachelor. Upgraded to pellets (thanks to this forum) and now to a propane boiler system. No longer interested in using these chimneys because, in addition to poor condition, they are extremely tall (high draft / difficult to clean), and I've got little kids and would prefer a safer location for a woodstove.
I'm now looking to add a one-story addition which will contain a new kitchen and a wood stove (possible cookstove, but probably irrelevant here).
I'm aware of standard stovepipe placement advice / code for running up through the main roofline, but I haven't found much good information about a one story ell off a 2-2 1/2 story structure.
My concerns are
1) Safety, obviously. In most potential placement, the chimney would be at eye-level with a second story window, albeit 15-20 feet away. This is probably more of a psychological fear than a legitimate issue, I would imagine.
2) Draft. Again, in most placements of my addition, the chimney would be approximately 15-16 ft tall, 15-20 feet away from a 28 ft tall x 45 ft wall wide (eave end, north and south sides) or a 45 ft tall x 35 ft wide parapet gable end wall (east & west). All walls have windows. Given the size of the building, would I be creating some sort of dead zone of airflow that would cause smoke to linger or give draft issues? I've looked at placements where the chimney would be located 20" out from the corner of the main house, which would possibly allow better airflow, but it's an awkward set up.
My goal is to have a reliable source of back-up heat, and supplemental heat that will reach 1-2 rooms of main house. One story due to costs, but also would prefer to have a shorter chimney that I can maintain easier than the 35"+ dog-leg chimneys on the main house.
I hope I've over-thinking this and the house isn't a draft concern if the chimney is 20" or so out. Any advice is greatly appreciated.
Thank you.
My concerns are
Thank you.
