Let me set the scenario. We are putting in a new install wood stove. The room is like a barn, almost 30ft at chimney exit near the center of the vaulted ceiling. Pipe will all be inside until roof exit. only a couple of feet will be needed above the roof line. It will heat the giant room (approx 30' x 30') plus some other areas of the house that are connected in a fairly open floor plan.
Due to budget, I picked up a used wood stove that isn't as large as we wanted (we want a big one to heat that space plus other parts of the house). It has a 6" flue. We plan on replacing it in a couple years when we have the budget for a larger and nicer stove. I have a chimney installer coming to do the chimney. I'm too scared of heights to do it and our insurance needs someone certified to sign off anyways. He wants to use 8" pipe. He said a lot of the large stoves we might want may use and it would be good to have. He said since we have such a long run inside to not worry about the draft. I'm just concerned that 8" is too big. It seems most newer stoves use 6", even the big ones.
Should I pressure him to go 6" or would the 8" be more universal for future needs. I'm less concerned about this stove than the future ones, we'll make do for this stove.
