Hi all -
Recently installed my chimney pipe at the cabin. Cathedral ceiling, rafters 12" OC, reduced clearance (10.5") cathedral ceiling support box, 8" outer dia. DuraTech pipe.
At the penetration through roof, I cut the plywood back as close to the edges of the support box as possible. Maybe .5" inches shy of being flush. When I was getting the support brackets on the pipe, I needed to angle the pipe slightly toward one side to get it plumb. This was a little bit of a concern, because regardless of how you install 8" outer diameter DuraTech in a reduced clearance box, you're going to be less than 2" away from the combustible roof deck. This worried me, so I used some z-flashing to face all of the exposed roof deck, applied with high heat silicone. Now, no matter where the pipe sits, it's completely surrounded by a non-combustible material.
Does this seem OK to folks, even if the pipe was resting, or close to resting, on that z-flashing?
- D
- D
![[Hearth.com] Chimney Pipe Penetration [Hearth.com] Chimney Pipe Penetration](https://www.hearth.com/talk/data/attachments/163/163752-ab8f7d76f969a4537efc050b346c4b2e.jpg?hash=rSTrPvNeNV)
![[Hearth.com] Chimney Pipe Penetration [Hearth.com] Chimney Pipe Penetration](https://www.hearth.com/talk/data/attachments/163/163751-47425572a8a73352ad83e0d9778b8a84.jpg?hash=BWut_QLZXD)
![[Hearth.com] Chimney Pipe Penetration [Hearth.com] Chimney Pipe Penetration](https://www.hearth.com/talk/data/attachments/163/163750-eea968ad3ae004924f2aef964b3aba3c.jpg?hash=NYKVc98i8C)
