Hello,
If you're reading this, I hope you don't mind a bit of background detail. I appreciate any thoughts anyone cares to share.
I purchased an old New England colonial farmhouse this past summer and have been looking forward to purchasing and installing a Progress Hybrid, a decision I came to after much research and driving over to the Woodstock factory with diagrams of my home.
The existing brick chimney is in the exact center of the home and has been used for different purposes over the years. It has no fireplace, only a thimble with a 6" pipe in it and an old oil boiler attached in the basement that hasn't been in use for at least a decade. The previous owner had a soapstone wood stove of some kind attached to it that I saw from the previous listing's photos.
I hired a local chimney sweep to give me a quote on an install. He sent a young fellow out, not the chimney sweep himself but a "technician." Turns out the chimney has a metal liner already installed with mortar poured in around it.
He told me in no uncertain terms that I could not use the existing chimney. He said it needs an insulated liner or it's unsafe. He did not check clearances or anything like that. I asked if the mortar around the existing metal liner provided some insulation and he claimed it did not. A bit of internet research after the fact suggests that a poured mortar liner can be a nice insulator and can help restore strength to an old chimney like this one.
I hired him to send a camera up there and check the condition of the liner, which he did not do (and therefore didn't charge me, which was nice) because he took one look from the thimble and from the top and said this chimney is unusable due to the poured mortar and the metal liner.
He said my only choice is to demolish the existing chimney entirely and have them build a new one in its place, or place the stove against an exterior wall and run a stainless chimney through the wall and up the side of the house.
I am planning to get at least one more opinion here, but I wanted to check with you guys to find out if it's true that I cannot safely hook a wood stove (the Progress Hybrid is the one I care about) to this liner. If the metal liner isn't cracked or compromised (it is a bit rusty, I could see that), is it possible a more experience chimney sweep might tell me something different?
I had the distinct feeling this young man, while very friendly and a nice guy, just wasn't experienced enough to give me useful information about my situation. He believed an insulated flex liner is the only option for an existing chimney, period, and if there isn't room to fit one down there, the only option is to make room--which in this case means destroying and recreating the entire chimney in the middle of my historic home.
The interior of the metal pipe is 6". I don't know what type of metal it is.
If you've read this far--thank you! Any thoughts are appreciated. I very much want to be heating with wood next year, but I don't want to pay a fortune to demolish and recreate my historic home's chimney if I don't have to... and on the other hand, I don't want to be unsafe and burn my home down, either.
Cheers!
