Chinese elm
If you get it before wood decaying fungus sets in -
It's moderately heavy, dries down at an average rate, leaves an average amount of ash. It starts easy.
If it has started to decay, which can happen very quickly, judge whether it's even worth working with.
It can split easy, possibly if it's straight grained and also maybe if it's frozen solid.
Or it can split into a million strings that never seem to want to seperate.
Attached is a pc of straight grain smooth white oak, next to a lovely piece of miserable splitting elm.
  • [Hearth.com] Chinese elm
Reactions: XmasTreefarmer
Comes with its own kindling
Reactions: Sawset
nothing wrong with it, works fine, about those nasty spliting habits - well i seen the same in hickory and a couple others i do not know the name of . Box elder can be a royal pia and anything else that gets all twisted up. Free is good
Reactions: Sawset
Tough as hell to split when green. It makes heat. It's pretty dense. If you don't mind splitting it, free is a great price.
Much confusion between the two. Chinese elm: Siberian elm (U. pumila) ? OR lacebark elm aka Chinese elm (U. parvifolia) ?
https://dendro.cnre.vt.edu/dendrology/syllabus/factsheet.cfm?ID=90
Probably doesn't matter that much for wood burners, but for landscape industry in past decades it's caused headaches (and lost $).
You probably have Siberian elm U. pumila, as lacebark elm has a very distinctive, beautiful exfoliating bark (It's also slower growing but not as hardy) and is less common.
Sometimes Siberian elm (U. pumila) can look a bit like red elm/ slippery elm U. rubra, but leaves smaller (and slippery elm leaves are scabrous (rough) on the top side). Look for characteristic signs of bacterial wet wood staining (white/ light patches dried slime flux ooze on bark), and characteristic stinky-ness. Siberian elm bark is grey with coarse furrows.
Siberian elm is weak-wooded; it's an introduced species that really has become invasive in much of US, especially urban areas, so there is always some Siberian elm turning up for wood scroungers after storms, and along utility trims.
I haven't (hand) split much of it, but sometimes decent sections are much easier to split than other elms.
It probably burns similarly to other elms ?
Reactions: JimBear
I've burned plenty. Good stuff. Not sure about the picture above. My Ch. Elm does not ever appear that stringy! Maybe what I have always called Ch. Elm really isn't? I am actually working through a very large specimen in the back yard right now. Definitely hydraulic splitter material to be efficient. Hands down.
American, Chinese, Siberian
Never looked into the differences. The trees we have in the woodlots and fencelines here continue to die off before the age of 15. There are what looks like Elm wind breaks nearby though, that have been there for ever. Need to take a closer look.
75 footer. Lots of splits. Standing dead for a couple years before I dropped it. Over limit wet on the moisture meter. Squeezing water out while splitting. [Hearth.com] Chinese elm[Hearth.com] Chinese elm[Hearth.com] Chinese elm
not unusual for the stump and a few feet above to be wet due to capillary action. bet the top branches are pretty dry
As far as using it for stove chow...not bad stuff. I would rate the stuff I burn at slightly above average for heat.
Reactions: JimBear
Open grown white oak can be as bad or worse. Every round can have a branch, and every branch could need to be ripped apart.
All I remember was helping my grandfather build a splitter to put on the back of a 194? Allis Chalmers. And how we spent more time bashing pieces off the wedge than splitting. Burned well though. I’d take for free.
