Chinook 30 not heating the house
Bambi W
9
Mccall idaho
Hello trying to figure out what I am doing wrong or if there is a problem with my new stove.
We have had our Chinook 30 installed professionally. 22ft of pipe. We have a new construction house. Cold air intake installed and using energy logs. I can't get the house warmer than 59 degrees. In fact if your not standing directly in front of it your cold. The fan kit is blowing hot air but the room never gets warm.
Any advice is welcome. Thanks
Can you show a picture of (the fuel in) your stove burning, and one of the right hand side of your stove while burning?
Reactions: Highbeam
I have the same problem, but in my case it's not the wood, but the heat demands of the house just being greater than a woodstove can realistically deliver.
Do you know your peak heat demand, in this weather? How's it compare to the rated output of the stove, over the full course of a burn cycle?
Another way to come at this is to assume the heat output of your stove, averaged throughout the day, is 85% of what you put into it. If you know your wood is dry and < 20% MC, it's easy enough to weigh a day's wood, and get an accurate estimate of BTU input. If you know how much electricity or oil you were burning per HDD, you can calculate demand versus supply, and determine if you need more firepower.
This step to verify that your bypass is closed and that your thermostat setting is to max.
Those energy logs, the NIELS I assume, pack plenty of dense, dry, punch.
Then some details about your home. How big is it? Is the stove in an uninsulated basement? It's not that cold this year in the PNW, though the next week we'll be having a cold snap.
Reactions: stoveliker
  • video000000.mp4
    922.3 KB
  • [Hearth.com] Chinook 30 not heating the house
The new home is 3339 sq ft. It's in a living room. Blown in insulation. The living room temp is at 59 degrees. The stove never reaches a temps to get pasted the 1 o'clock position on the dial. That is at full temp. Not dialed down at all. I don't think my cat is working.
Put more wood in the stove and move the stove away from the wall some so the thermostat works properly. Also how tall are the ceilings in your living room
Reactions: GG Woody
That dial doesn't tell you the stove temp. It only tells you whether the cat is active and should not be used for anything else.
That said new cats are generally overactive rather than anemic.
I agree with bholler; You need more fuel in the stove for more heat output, and it's possibly too close to the stone.
These stoves are meant to be filled with wood and run for many hours per cycle.
Reactions: GG Woody
I would try more wood first the distance to the wall may not be causing a problem i am concerned about clearance to combustibles though what is behind that stone?
Is the pipe straight up?
Is the OAK not obstructed (e.g. drier damper mistakenly put on the outdoor wall?)
I had a conversation with @BKVP about this wall distance issue, when I was installing my two Ashford 30's back around 2014/15. If I recall, he said to try to keep the stove at least 6" off a stone wall, although after hearing I might need to get closer to 4" in one of my installations (in order to close the fireplace doors in summer ;lol), he said to give it a try and see how badly it affects the thermostat. Since I have two identical stoves running on the same wood in the same house, I made a good test case.
In my case, the 4" - 4.5" gap to a stone wall seems to work fine, it doesn't have any major cooling effect on the thermostat at that distance, but I would caution going any closer than that without some experience or experimental control (second stove?) to which to compare performance. It does appear your gap is even less than 4".
That said, this would affect the ability of the stove to self-level and provide even constant burn rate throughout the cycle, and shouldn't be a factor in max output. I'm with bholler and stoveliker... stuff that biotch to the gills, get cat probe themometer near active, close the bypass, and let's see what she can do. If your chimney is 15 feet tall or less, there's no harm in letting it run wide open throttle through entire loads. If you have more chimney, knock the thermostat back by 1-2 hours on the clock face from full throttle after the first 15 minutes, or install a key damper to manage the stronger draft that will develop in a tall chimney at full-bore.
Reactions: Dieselhead and BKVP
Yes, but your walls are massive stone, so cold.
His is veneer on a stud wall, I think, given the new home. So they might get much warmer, leading to a thermostat that closes earlier.
Regarding "stuff it full", with sawdust logs that's not advised, according to BKVP.
(Though I did a test to see the "run away potential" by burning a bucket and a half of 1/2" sticks that had been in my stacks for more than 4 years - don't ask - and there is zero run away potential: got it ripping, closed the thermostat, boom, no flame (possibly overwhelmed cat, but no run away.)
Reactions: Ashful
Question. The stove meets clearances. The fan kit is what is close. I had this professionally installed. I will talk to the installer and see what we can do.
We also added more wood and that didn't help either. I appreciate all your comments each of you. Thank you. Let me see about getting another piece of pipe.
Reactions: Ashful
We also have a cord of red fir that is seasoned that we are burning with the energy logs. I will go and buy some pipe on Monday and give it a go. I really hope that is the ticket.
Make certain bypass is closed AND locked.
BKVP
Reactions: BC_Josh and Ashful
It sounds like your fan is running even tho the cat thermometer is in the inactive range. Does the fan draw the cat temp down when the cat thermometer is showing "active"? One thing I would do is put a magnetic thermometer on the stove top. Whatever temp the thermometer would show really wouldnt mean a whole lot. Other than let you see temp patterns as the stove is running. Over time you would associate stove top temps with heat output. Also, does your cat ever glow orange? It would be strange if it doesnt.
Turn off fans to get accurate cat temp, per the manual.
BKVP
To be 100% crystal clear, fans do not have any major effect on cat temperature. But they do impact the reading of the probe, as they blow cool air across the probe shaft.
The CK30.2 has a decorative top above the firebox. That surface isn't indicative or a good way to gauge temps.
BKVP
Reactions: Ashful
BTW, unless you really had your heart set on 100% heating via stove, having a stove that's a bit under the ability to heat the place on the coldest of days isn't a bad thing, as it likely means you're well-sized for maximum efficiency during the longer part of your heating season.
No matter how hard I run my stoves, I need to run the oil-fired boiler to add heat to the house, the number of zones of which trigger off according to how cold it is outside. Back when I was away from home all day, this meant I could just load the stoves twice per day, and let them supply heat to carry the majority of our total load, while the boiler and automatic thermostats modulated the final comfort atop the constant base heat supply that is the stoves. My savings still followed my wood usage, even if I was burning some oil to throttle the final few degrees between the stoves and our desired room temperature.
The secondary advantage to all of this is that you keep your central heating exercised and functional, such that going away for a few days mid-winter or an unexpected illness or injury does not create a heating catastrophe for your family to deal with.
Reactions: all night moe
So, how big is the living room where the stove is? And where did you measure the 59 F?
How high are the ceilings? 15 ft? (22 ft pipe)
Does all the heat pool near the ceiling (as physics dictates)?
If so, a ceiling fan may help (in the setting where it does not "blow downwards", but blows upwards; the warm air will then glide along the ceiling and then to the walls where it'll go down to replace the air being sucked up in the middle. This avoids sitting in the stream of air under a fan that blows down, which will lead one to feel colder than needs to be. (I know this does not negate your 59 F measurement, but it's useful nonetheless.)
I think that second, bigger load should reach a proper stove temp that it sheds good heat.
Is your fan running low or high?
I have the exact same stove and have no fan. It runs in my 825, but only 7 ft ceiling basement - but I use it to heat my whole home.
And indeed: is the bypass "cammed over"? (at least it's more or less closed, as the first pic I asked for shows). Want to avoid heat going up the flue.
THen: do you have a flue probe? Useful in running the stove - and very important now to determine if you are somehow sending all the heat up the flue.
The living room is 20x20 with 12ft ceilings. No ceiling fan. But no heat felt unless you stand 2 ft in front t of the stove.
We used a thermal for temp in the dining room.
I have the bypass in the correct position locked forward after reaching proper active zone with temp on max position. Fan full blast. As per other recommendations we are going to move the stove out away from the wall.
I don't think moving the stove is going to change the heat output much - depending on the wall temp. Did you measure that?
My drywall behind the stove (at 1.5 times the clearance) can measure 110 F (IIRC). I don't think that affects the thermostat much.
"feeling the heat" is not what this stove does well - other than right in front of it. It sheds most of its heat by convection.
And having the fan on full blast will also make it feel less hot (even if BTU shedding slightly increases).
And at 12 ft, in a fairly large room, all of that will be at the ceiling.
I think you need a ceiling fan.
And a flue probe; if the heat is not going up the flue (measured with a flue probe), it should end up in the room. It does not disappear. (At least, that wall behind it is stone veneer on studs, right? Internal wall or external?)
If you don't feel it, it's high above you.
I don't know what you mean "thermal for temp in the dining room" - earlier you said that the living room was 59 degrees.
Can you draw a sketch of the home layout (including door widths, windows), and where the stove is and where you measure that 59 ?
It is venner stone and stud wall. Internal wall. We have the stove in alcove and the ceiling is cold on that. We have a heat gun coming Sat in the mail. To check the flue.
New construction house. Ceiling fan goes in next week
post a couple pics of the room. How big are the doorways to other rooms?
Keep that stove going all day and night with full loads. See if it can catch up to bring your indoor temps up.
What's the outdoor temps?
Looks to be pretty cold in idaho.
