Hello-newbie here with a quick question. We moved into our home a year ago, and decided to go with wood heat due to struggling with oil/gas/ and electric heat cost(yes all three-this was the existing lay out) The owners before us installed an oil furnance with duct work through half of the house and had two of our four chimneys rebuilt with cinderblock. One is for the exhaust, but the other, upon our inspection in the cellar, is not being used by the furnance. There was a circle shape on the wall outside of the chimney in my dining room, and thinking it was the flue, I knocked the wall out around it only to find that there isn't one-yeah, you should of heard my husband. So my father came over and seen the cinder block chimney and said it was a no go-that the wood heat would cause it to crack, and since it's going between walls, it will be a major fire hazard. So, basically I was wondering if there is a way to use it, like lining to inside with proper pipe, or if I should go ahead and buy some drywall and replace the wall, and just forget about using wood heat?? Any help greatly appreciated!
