Hello-
I recently had a 6" class A chimney installed straight up through the ceiling and then the roof. The pipe is clearing the rafter by 2" but is in direct contact to the OSB sheet under the metal roof. Is that cause for concern and should I contact the contractor to cut away some more of the OSB?
Thanks,
Chris
Thanks,
Chris
![[Hearth.com] Class A Chimney touches OSB sheet when exiting through the roof [Hearth.com] Class A Chimney touches OSB sheet when exiting through the roof](https://www.hearth.com/talk/data/attachments/202/202110-82b294ceee18c9f4f1527470e42b70cd.jpg?hash=J66dBWkRnZ)
![[Hearth.com] Class A Chimney touches OSB sheet when exiting through the roof [Hearth.com] Class A Chimney touches OSB sheet when exiting through the roof](https://www.hearth.com/talk/data/attachments/202/202111-d6cccb8c2b80b8dbc533d6a92f9b6704.jpg?hash=YVl_TJ9voB)
