Installed one of those classic dampers yeaterday to cure a draft issue. Is there a trick to getting to getting the damper control from wanting to close on its own? The spring does not apply enough tension.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
