Cleaning Cast iron Surface
ltlhawk
Burning Hunk
111
Pelham, NH
Hi Guys,
Today after cleaning the inside of the stove I was wiping down the outside with just a dry towel and I noticed that it has a slight white film that looks like streaks and I cant seem to wipe them off. Is there a trick or product that you can recommend to clean the outside of cast iron....? I tried just a towel with water, but that did not work. It also made me nervous about rusting so I used very little water and dried it off very quick.
Thank you
Does the WD40 smell up the room once the stove gets hot?
You may want to try stove polish. I used it on may cast wood burner made it look like new. There are several threads on here about polish vs paint.
No it doesn't smell. I use just enough to make cleaning easy, then try to buff it off. I use it during the summer to guard against rust (whenever it becomes visible), does a decent job. Its used on the cast iron face of my stove, which is painted matte black. Its not enameled so its porous. Ive read a couple brands of stove polish which say not to use on paint, at least the ones ive found. I didnt want to try it, and i knew wd40 is ok for paint. if its not painted, then go with the polish.
I am not sure if it painted.. The surface is very rough, but also very black, so maybe... thank you for the information..
Bear fat.
Wipe on, wipe off.
