Clearance Reduction
cham1733
35
14057
Hi, I am hoping someone here can clarify some questions for me. We just bought a Dutchwest 2461 wood stove. We are looking at the manual and I am a little confused on the clearances from the side of the stove to the wall. The manual says if it is an unprotected surface it is 22in but if it is a protected surface it is 12in. Now I know are walls being drywall are an unprotected surface but it would be ideal if we can knock 8in off our clearance to the side wall. The reason being it is going in our basement and to have a 22in clearance the chimney would be running right smack dab in front of a bedroom window. So my question is what is the best way to reduce the clearance? I was looking at heat shields but would putting a metal heat shield an inch from the wall reduce our clearance to 12in from the heat shield? I am not sure if a heat shield would be considered a protected surface if it is just in front of our wall. I have attached a picture of the manual that I am looking at. When I called our town building inspector I was told that there is no set defination to how much a heat shield would reduce clearances so if it is not in the manual that we can't do it. Any help in appreciated.
a heat sheild is a non combustible material spaced an inch off the wall with an inch gap at the bottom to let air in and the same at the top
Ok. So with a heat shield positioned as you said above would that classify as a protected surface now? Sorry if this is common sense, I am new to all of this.
Yes that is how nfpa211 instructs you to make a heat sheild and that would then be a protected wall
Is the stove going in a bedroom?
No, it is going in our basement. However, where we are looking at putting it is near our sump pump which is enclosed.
[Hearth.com] Clearance Reduction
here's the table on the materials listed in NFPA 211
Edit: sorry if it's a little small
