Closing up old basement fireplace
hydes2004
153
Rhode Island
Hello,
I have a fireplace in my basement that is unused and we would like to close it up. The fireplace is in the foundation. We will be finishing our basement in the near future. What would be the proper steps to close this up? Do I fill it with concrete? Cap the flue but allow some airflow up top? [Hearth.com] Closing up old basement fireplace
  • [Hearth.com] Closing up old basement fireplace
Id install an insert.
I'd cap it and cover it over with the option of access to reveal it later in case you decide to. Even leave it as a cubby, install a light in it and put some cool nick nacks in there.
Is that a 5.5' tall ceiling? I couldn't even walk down there.
A 30x30x30 cubby would hold a largeish minifridge nicely. Or maybe a cool looking old smoke dragon used as a storage cabinet.
I think I'd use the space but block the flue with plywood to catch falling crud and/or bricks. ;)
You will still have to maintain that old chimney or it will leak water into your finished basement eventually.
I would like to close it up for good. Vapor barrier and frame it off? There is a French drain up against it already in case any water came in
If you keep the chimney capped and well maintained, no water should get in, and you can always poke a hole in the wall to get access.
You could put a piece of cement board in the opening, and frame around the opening like a window so that when you need to get in there, it'll just be a piece of drywall and a piece of cement board, and not several studs in the way. Maybe give it a couple verticals in the middle, but just toenail them once at the top. That is easy to remove and still supports the drywall in case somebody leans on it.
Pouring it full of cement is a permanent solution, but expensive, and it ruins the chimney. Filling up just part of it leads to the risk of water leaking in higher up in the house.
