Clothes washer maintenance?
EatenByLimestone
Moderator
Staff member
Does anybody do clothes washer maintenance? I can’t remember seeing anything other than upgrading the water lines to braided stainless ones. My wife also leaves the door open.
But there is maintenance performed on dishwashers, dryers, furnaces, etc. All other big appliances get regular maintenance. Are we missing something here? Could we extend the life out years with some sort of maintenance?
This stems from a video that popped up on my feed of a hopefully extreme example.
Reactions: Burnin Since 1991
There are cleaning tablets to use. The front load I had before we kept the door open. Also it had a filter on the bottom front. I now have a very old (17yr) top loader. I like top loaders, but this one had/has a problem leaving black marks. I thought I had cleaned it a while back, but I think it may have left more black marks again. I don't believe it's grease, just black "dirt/mold" . I plan on getting a new one next year as I am not taking it all apart to do a deep clean.
Yeah some models have a filter/trap to clean once in a while...model specific as to if it does, and where though...
Reactions: bigealta
Front load LG. I drain and clean the filter yearly, located bottom left side on the front. When we get a Low Water Pressure error message I clean the intake screens on the hot and cold intakes, located on the back of the washer. We’re on well water and do pickup sand, when we were on municipal water didn’t need to worry about the intake screens. Wipe down the rubber door seal inside the fold after use and leave the door open for a day or two. We also leave the soap/bleach/fabric softener drawer open and wash the soap and fabric softener compartments as needed.
Furnace is filters every 2-3 months, vacuum out the dust where I can reach yearly, clean the thermocouple yearly, check belt yearly if equipped, replace programmable thermostat batteries yearly. Every 5 years it was recommended to me to replace the thermocouple, it’s considered a wear item. My furnace guys recommendation, part is $11.00 and will eventually wear out and stop working.
Hot water tank(electric), drain yearly. I don’t check the anode but should.
No details offered on the wood stove, I’m confident you have that figured out.
I share the dish washing with my wife(no dishwasher) she by far is the highest maintenance item in my world!
I have a top loader. It looks like I don’t have filters that the front loaders do! Lol
Yup clean out the filter behind the little door on the bottom front of many front load washers.
The drain hose should be right next to the filter that you can unscrew. Drain the little hose first so u don't get water all over the place. Some people call that filter the coin catcher.
We leave the lg front loader door open all the time. same with the detergent dispenser. And no fabric softner. That stuff is NG.
I think Citric acid is the preferred method of cleaning washers with gunk buildup.
I have a Maytag top loader from 1985. I clean the trap in the center agitator once in a while when I remember to. I've also replaced the drive belts once or twice.
Hi,
It's nice to see someone still has their older model washing machine from '85. We have a Maytag from '94 that is at our fixer-upper house where my husband stays while at his current job. He recently changed out the belts. It's the good old style, where you can still fill it with hot water and stop the fill by pushing in the mechanical knob. It, too has a clean out filter on the top. That house has excellent water, perfect PH, no hard water, so it only needs cleaning occasionally.
We also have a two year old top load budget model LG washing machine. It's supposed to be energy efficient, water efficient, but I find that often it is neither. Since the water heater isn't near the washing machine, I run the hot water at the utility sink until it runs hot. It also runs much longer than the old machines from the 90's and prior.
As long as you don't have water softened water, you should be okay with it staying in good condition. The LG machine has a clean setting, but it doesn't fill it up all the way to the top, so I use the Beddings and Pillows settings, select Hot, and use 3 cups of white vinegar. Doing this once a month helps prevent that white lard like substance from building up on the bottom of the tub.
We also have a 2005 Fisher & Paykel top loader. I use it to wash the pet beddings. It's manual says to use a large cup of powdered detergent to a full, hot water cycle.
My brother-in-law has city water-softened water and the sodium in it rusted out his stainless steal tub within 7 years.
I deep cleaned the tub a few years back when I had the whole thing apart for what reason, i forget… might have been replacing the transmission. I’m not real happy with our aging washer, it has real trouble with balance (of course that might just be us overloading it all the time because of pets and kids) that ever never been able to really address despite replacing springs and pads and so on. Still better than some WiFi Bluetooth AI enabled piece of crap though. In our climate and with as much as we use it never has much chance to dry out so we found throwing some baking soda in (or just rags that you used to clean with baking soda) keeps it from developing that funky smell
Now, our old dryer? I’ll keep that going until I can’t get parts. Easy to work on, does a great job, no computers…
