Hi,
I just purchased a used natural gas fireplace insert. This insert was made by Superior around 2000 but still works fine. It has a 2" intake and a 3" exhaust co-linear vents. I have done a lot of research and cannot find a kit that comes with a chimney cap and the 2" & 3" liners. I have called a few companies that could fabricate me one for around $550.
My question is can I save money by buying a single 3" exhaust liner kit with chimney cap ($60) and then buy a separate 2" liner that would pull fresh outdoor air from the side of the chimney ($25)? The exhaust will run to the top of the chimney about 30 feet and the intake will run up the chimney about 6 feet where I would tap a hole for the 2" to run outside.
Option 2: I could run the intake down into the basement (through my fireplace ash clean out) and pull fresh air down there.
Option 3: I have read that some people don't even run the intake liner all the way up the chimney. That they run the exhaust all the way up then leave the intake half way and let it draw air at that point... any disadvantage to this?
Correct me if I am missing something but I do not see the advantage of running both intake and exhaust liners up the chimney for $550. Especially since the insert is 18 years old and is no longer under warranty. All opinions and advice is appreciated!
