I have a 1995/6 Austroflamm Integra 65 insert needing a replacement combustion fan motor. The original OEM fan motor is listed in the owners manual with a part number being #104278 and I cannot not find the listing anywhere. On several other online pellett stove sites another fan motor that "might" be a replacement is listed with a part number of #102831 and I'm trying to confirm and cross reference that this part will work before dumbing $200-$300 into something that will not work. The replacement listing usually states that if you are replacing a pre 2005/6 combustion fan motor you will have to reuse your old wiring terminal ends. Can someone confirm that this new part numbered motor will work? Has anyone come across a similar situation? This is the first and only real issue I've ever had with this stove and would like to keep from having to buy a new stove.
