I'm stumped. I read that some guy takes his come along and attaches it to the tree he is about to cut. He puts it under tension so the tree will fall in a different direction than it would on its own. It sounds like a good idea. Is it safe.
Other than the fact that the cable can snap and slice your head off, it's pretty safe.![]()
i feel like using a come along to fall a tree is self explanatory... is it safe? if your asking how to use a come along to fall a tree, then no.I wonder if barmstrong could tell me exactly how he uses the come along and if anyone else uses it before they start to cut down the tree
Sure! I'll use a come along when I want a little extra insurance, if a tree is really not wanting to go where I need it to go. Along with wedges and other felling technique, I'll tie a chain off to something more solid than the tree, preferrably a bigger tree, and pull tension on the come along BEFORE I've made any cuts that could fell the tree. I'll usually double check the tension and take it up some before making the final back cut.I wonder if barmstrong could tell me exactly how he uses the come along and if anyone else uses it before they start to cut down the tree
Is it safe? Of course not! Nothing about felling trees is safe!
X2Don't use a come along but a rope tied to the tree and attached to the four wheeler or tractor quite often to redirect a tree
The OP who started this thread said his friend uses a come along to put a tree under tension before he starts cutting to force the tree to fall in a different direction from its natural fall line. No one has mentioned the danger of experiencing a barber chair effect by doing this. It is very dangerous cutting a tree that is under tension due the possibility of the tree "exploding" back on you when you reach the point in your cut when the tension overwhelms the remaining strength left in the tree to remain standing. I've used a come along to pull a widow maker down off the tree where it is hung up, but this is an all together different process.
