What to do with the wood
Tbob
3
Washington
Hello - new here, I am looking for some guidance and suggestions on our situation. Sorry if this is a little long, trying to give you all the information. Thanks for all the help and the knowledge!
Our experience- We have had wood stoves in past houses but always bought logs or split wood. We usually would only purchase by the cord.
We purchased a fixer upper cabin in NE Washington on almost 8 acres surrounded by the national forest, which we love. This time of year we try to figure out the priority for next year, how we are going to pull it off and budget it. There are currently four major fires in our region and one near by, this has increased our concern about our forest and what we can do to help prevent fires. After meeting with a couple different experts, retired fire chief, wild fire fireman, a couple old time locals 🙂, and a retired ranger from the national forest, we were given a handful of suggestions. We are planning on trying to execute those over the next couple years. We will be thinning out certain trees, removing a handful of dead trees, and pruning up the trees. The question is what do we do with the wood? We plan taking at least three big trees down and about 10-20 smaller trees next spring. How should we be storing the wood? How long does firewood store? What is the minimum diameter log diameter for a woodstove? Is there a wood we shouldn’t be burning?
Since we are not there full time, we currently keep the cabin at 50 with a lopi cast iron propane stove and some wall heaters. We like the idea of different forms of heat in case power goes out or run into issue with gas we have backup heating options. The cabin is long with three sections, on one end is a living room, were the propane stove is, than in the middle is hallway with bedroom, laundry room and bath off, than the other end is kitchen and dinning room. While we are there we do use our big e pellet stove which is located in kitchen and dinning area to help with heating. We do get down to negatives but on average we are in the teens with a good amount of snow in the winter. Between the big e and lopi the cabin stays really nice no matter outside temperature. We are thinking of moving the big e to our small shop and installing a woodstove in kitchen dining area. We were suggested a couple different brands, Drolet and blaze king kept coming up. Still trying to figure that out, our hesitation with blaze king is the amount of heat it would put out might be too much. Our cabin is about 1400, the area where the wood stove would be is about 500 square feet with a doorway that leads to hallway. Any suggestions on what woodstove you would get, is greatly appreciated! We don’t mind investing to a better stove if it will last but also don’t want to spend an arm and a leg 😜.
You don’t mention the wood species. Cut logs into stove length (16” is common), split and stack off the ground, ideally it should be covered. Sounds like you have lots of wood which gives you options.
Lots of options for stoves, many forum members will have better informed opinions than me.
I just replaced a Blaze King with another BK. They do cost an arm and a leg but I sure like them. Winter is reloads every 12 hours to about -20C. Once we get into the -30 to -40C reload is every 8 hours, 1700sq. ft home with a bit of supplementary electric heat in the furthest room(bath)
Reactions: GG Woody
Thank you so much for the response, from the trees we are cutting down next year we have a mixture of pine, larch but I have heard them referred to as tamarack, birch (mostly birch the first year). We also have a sprinkling of a couple other types but I don’t think we are cutting those down. We have some aspen but I think we are going to chip those since the diameter is not big.
We have been told that the upper half of our acreage is “virgin forest”. That is the area we plan to thin manually, we are trying to save and protect the old growth trees. We actually didn’t even know they were in there till I weed whack some trails in so we could survey that part.
The retired logger who came out thinks when we get all done we should have about four or five logging trucks of good size logs. Unfortunately we are off a forest land road so getting it out can be done but it probably is not worth it he said? He recommend just using it or giving it away if people would haul it. I was informed a couple charities would haul it out and give it away in the colder months so there is that option.
Do you recommend a structure to store it? Or what I have seen a lot on line is pallets with some type of tarp or metal on top? How do you store your wood?
Thanks for the recommendation of blaze king, they are made about five hours away from us, we like that they are made in Washington 🙂. I think that is the way we are leaning because of how often we pile have to reload.
Thanks again for the response.
You said you had a fixer up cabin, so I assumed your efforts would be going into fixing the cabin. Lots of ideas on this forum for some impressive woodsheds members have built.
I use pallets with scrap plywood as cover, two 30’ log’s laid on the ground with no cover and some in a wood shed. It’s all about your priorities, time and $.
I wouldn’t rush into any quick decisions with logging other than what’s needed for development. Take some time and explore some of that virgin forest before making any decisions. People pay a lot of money to explore virgin forest and you’re living in it. My dad, a Forester, would see commercial value to a wood lot while I’m counting deer and looking for a suitable tree for a stand. We’re back to priorities, time and $.
BK also has a Canadian facility so I’m buying “local” also. Keep an eye out on the used market.
Reactions: GG Woody
If you have multiple loads of tamarack, I'll bring 20' trailer and haul them off just to help you..Around here, finding tamarack (Western Larch) is very challenging! Seriously, you can get $300 a cord for great firewood. Sell some and buy a stove.
BKVP
Though I have made various wood sheds from pallets and treated lumber, lately I have been using metal cages which are 275 or 330 gallon IBC cages (aka water totes). This way carpenter ants/bees and termites do not eat the basic structure.
You can use the plastic tanks to make roofs various ways. I like building a small roof when I have time to keep the wood dry. Basically a 1 foot over hang front and back and on the sides, top is vented, though not really visible. I fill in space at the front so vipers do not strike if getting wood or stacking it.
I put the cages on CMU/cinder blocks so the steel does not rust.
[Hearth.com] What to do with the wood
There's no minimum diameter of log you can burn in a stove. You can burn all 2 inch branches (cut in 16 inch sections), if desired. Though it would have to be fed very often. It's more a question of what sizes are worth your time. My wood stacks are all splits, or rounds that are at least 4" in diameter. But I also use a considerable amount of small dead stuff that falls from our trees. Small stuff can be very useful at times.
On every truck load you are going to be losing at least $500 because that is about the minimum cost for a CDL driver, trailer, and truck. If you bought a non CDL straight truck and 9990 GVWR trailer and the mill was not too far, you MIGHT make some money on pulp wood. The $ would be in trailering out the logs yourself to a place that will pay you buy the board foot.
Buy or make a ProCut chainsaw mill trailer. I bought my first one and then built my second one. It is something that does well off road. In this area you can sell hardwood lumber for at least a $1 per foot right off the mill.
Consider a log hog:
Probably buying one myself since I pretty much turn anything over 1.5" into firewood on hardwoods and anything over 3" on pine into firewood. If you cleaned the branches (skimmed) and trunks you could sell the bags of chopped logs. I have a setup gizmo for my chainsaw, this looks much quicker with uniform lengths. The best thing about the smaller firewood is it dries very fast.
What is nice about the bags, even for your own use, is you do not have to stack it or pick 100 pieces from a pile/tote, put them into a wagon or cart, then bring it inside. This way you just pick up the bag, put it into a cart/wagon, then just dump it into a 44 gallon barrel to fed the stove.
The only real caution is it is too easy to build a quick roaring fire that can get out of control if you stuff the firebox, especially with pine.
