Comfortbilt HP22 VS Harman P61 I need help.
Joe.G
Burning Hunk
Jan 21, 2018
122
NY
Hi I have a Volgerzang 5790 now and I am having some issues with it and can't seem to figure it out I have used it as a sole heat source for 12 years. I am thinking of replacing it with a HP 22 or the P61. I need it to heat about 2600 SQ heat which current stove does without issue.
I know Harman is the gold standard but is it worth double of the HP22? Would they both heat the same or better than the 5790?
Thanks
I wouldn't "through in the towel" with your present stove so quick. Seeing it has done the job for 12 years.
Quick search there seems to be parts available for it:
As for your options: Made in China, HP22 or Made in USA Harman. The choice is obvious to me. I have two Harman's, P68 bought new @ 19 years, and a P38 bought used @ 15 years. Never let me down, parts available and I can fix.
I know It's your only source of heat and winter is here, so you don't have time to waste.
Tom
Reactions: Joe.G and Washed-Up
If you tell us what the problem is with your stove, we, as a group, may be able to help you.
Repairing a known stove is a lot less expensive than buying a new Harman . Here is what is said about the
HP 22 as a total unit. Harman makes a good overpriced stove . Search the forum, and you will find more
running problems with a Harman than any other stove. They can be hard to set to what you want and
seem overcomplicated to me. The HP22
[Hearth.com] Comfortbilt HP22 VS Harman P61 I need help.
ComfortBilt HP22 pellet stoves are assembled in Ningbo, China, using parts sourced from Europe, North America, and South America, followed by a 24-point inspection upon arrival. [1]
Manufacturing & Inspection Details
    • Sourced Components: Uses parts from North America (including the U.S.), Europe (such as France and Germany), and South America. [1, 2]
    • Quality Check: ComfortBilt's inspection team performs a 24-point inspection checking motors, switches, ignition, and airflow performance before distribution. [1]
    • Certifications: The HP22 is EPA and CSA certified. [1]
More technical specs and manuals are available on the ComfortBilt HP22 Resource Center, and product listings appear on The Home Depot and ComfortBilt. [1, 2, 3]
Reactions: Washed-Up
Current stove has been fighting me with a low flame on low and either going out or really getting the glass full of creosote, I have replaced room blower, Auger shaft,auger motor ( Tired a 1 RPM and 1.5 RPM ) ,auger bushing. Stove is spotless. I tried different pellets. Last night I replaced the door gasket and combustion motor. it seems to be burning a little better, still a low flame but not going out and only getting a little black on the lower edges of the glass.
Burning issues started end of last season. I have spent a lot of time messing with the stove this season and just getting tired of doing so. Hopefully I am on the right track at the moment.
