I was so close to going with a wood insert but i am not a fan of the pollution that it "can" cause.  I also believe that gas is a more popular choice in a residential setting (ease of use, remote control, etc.).
I do not have gas available so I would have to have a propane tank installed.
Should I go with direct vent? I have concerns over the moisture problems and CO2 emissions with a direct vent. I guess, in summary why shouldn't I go with direct vent? What are the absolute drawbacks that I should be aware of.
Are the direct vents expensive to operate in contrast to heating a room with my conventional, oil furnace? I am not looking to use this as a heating source, I just do not want to continue to have to leave a damper open with my wood fire up until the coals are completely out. A lot of oil heat goes out the chimney over night and I would need expensive, custom doors (stone fireplace) in order to address this
Your thoughts... thank you
