Uhh-you might want to look it up. Rust is mostly caused by moisture coming in contact with metal. Corrosion is usually caused by chemicals coming in contact with metal. Corrosion is more of a white substance. Rust=brownuhhh rust is corrosion.
Read the beginning of the section on rust in the article you poseted it saysUhh-you might want to look it up
The only definition i have ever seen says that it is corrosion on ferrous metal No interpretation required.I guess it's all in how one interprets the definition between the two.
Yes back on topic just clean it up with a scotch brite pad wipe it down with a solvent then respray it with stove brite paintThat went astray quickly
They will not replace the door there is no damage. If i sold the stove i would gladly repaint it for you if that happened in a year so i would call your dealer and see if they will. But no they will not replace the door for that.Damage after one year, I'd talk to my edge. Worth a phone call to see if they will replace the door. Also get it on the record in case other things crop up.
If my door looked like that after a year I'd be calling and looking for a mutually acceptable fix.They will not replace the door there is no damage. If i sold the stove i would gladly repaint it for you if that happened in a year so i would call your dealer and see if they will. But no they will not replace the door for that.
Agreed but paint is a perfectly acceptable fix. Regency will absolutely not replace that door for that little bit of rust.If my door looked like that after a year I'd be calling and looking for a mutually acceptable fix.
Didn't expect a science discussion!We use essential cookies to make this site work, and optional cookies to enhance your experience.
