I'm replacing the whole gearbox, at a cost of $300. This was in my snowblower- I sucked up a big flat rock evenly with both augers, which jammed both sleeves against the auger drive shaft so that the shear pins didn't pop. The snowblower is 10 yrs old, but it's an Ariens and has never given me a lick of trouble- I think I'll get another 10 out of it with this fix.the gear is probably designed to be the weak link, now getting it apart to change it is another story. soaking, heat and pin punch as stated above. Mke sure it is a straight sided pin not tapered, which means it will only come out from one side, not likely but possible.
I wish I could- they're pretty close to flush with the holeGot two pairs of vice grips? Get them oriented so that you are collapsing the gap on the roll pin. Just breaking loose the connection of pin to hole will help a bunch.
The roll pins hold the impeller to the shaft connected to the gearbox. Not that they would see some harsh conditions clearing my 250' driveway in NH for 10 years, but there may be a tad bit of corrosion. If I can't do it in another couple of sessions with it- I'll bring it to a machinist.
I have never been able to drill one out. I think the pins are harder than the drill bits.
Best way to remove roll pins is with a roll pin punch.
And, yeah, your gear looks broken.
http://www.brownells.com/gunsmith-t...-tools/punches/roll-pin-punches-prod5551.aspx
WINNER I'll personally vouch for roll pin punches as being the best way to get 'em out. That combined with a dead-blow ballpeen hammer and I've not had any roll pins I couldn't get out, yet. Big difference from going at it with a standard drift punch, also called a "pin punch" at times. Roll pin punches have balls on the ends.
Air hammers with the right tool in them can work wonders to. Mine hits about 3600 times faster than I can.
A good support jig and something sized appropriately to press the pin out via hydraulics would be a slam dunk last resort solution for me.
