Good to hear. That is a beast of a stove, I wouldn't mind sticking one into my fireplace. Have you filled that sucker up and gone for that Blaze King record burn?
Chargerman said:Well, its on.
First official fire of the season last night. It was cold in the 30's and very windy last night. Loaded the BBF with some ugly walnut pieces at 11pm and woke up later than I should have at 7am to a 300 degree stove with the fan on high.
Tommorow my father in law and I are adding a foot of blown in insulation to the attic. That should help quite a bit compared to last year.
I've had it up to as much as 1,300 with the fan unplugged (I wish I had a power switch on the fan controls!) My neighbor says I'm not burning the wood rightTodd said:What kind of temps do you get with the fan off? The fan will cool the stove temps down a few hundred degrees or more.
and the stove guy says that I need a new catalytic converter :$Chargerman said:I engage the cat on mine at 500 degress and it lights off fine. I usually let it get to 800 degrees this time of year before turning on the fan. If it is colder I let it get up to around 11-1200 degrees depending on the time I have available. I don't ever let the fan kick on automatically on the reloads.
The fan will knock the temp probe down a couple hundred degrees on the high setting. On the medium setting it will usually maintain the temperature that it is at for awhile and slowly come down. I have had it up to 1500 degrees last year without the fan on just to test it. IMO waiting that long just wastes the heat up the stack.
KevinB said:Chargerman said:I engage the cat on mine at 500 degress and it lights off fine. I usually let it get to 800 degrees this time of year before turning on the fan. If it is colder I let it get up to around 11-1200 degrees depending on the time I have available. I don't ever let the fan kick on automatically on the reloads.
Thanks so much...I was wondering if I was just crazy or had a defective unit! My neighbors all have non-cat stoves and all had different advice. One has a 30 y/o Kodiak that he can jam pack with wood and the thing can heat up his whole house. He is the most critical of my BBF saying it should burn hotter. I use oak railroad tie ends and can't use them until I get a good base of coals going....he can load hos Kodiak and open it up and they're lit in minutes. I realize I'm comparing apples to oranges, so I wanted to find others with similar units.
Thanks again!
Kevin
These are "raw" ends cut off before any treatment.Chargerman said:KevinB said:Chargerman said:I engage the cat on mine at 500 degress and it lights off fine. I usually let it get to 800 degrees this time of year before turning on the fan. If it is colder I let it get up to around 11-1200 degrees depending on the time I have available. I don't ever let the fan kick on automatically on the reloads.
Thanks again!
Kevin
I heat my 2300 sq. ft. house with mine 24/7. This time of year it is 1 or 2 small loads per day. I am sure that Kodiak will burn hot if you feed it wood. The big gain with the BBF over your neighbors Kodiak are the long burn times and clean burning.
I also wanted to add that both of my BBF stoves have a fan control switch and a on/off toggle on the front. Is your stack burning clean when you shut down the air supply? That catalytic will usually glow red for awhile during the burn if it is working properly.
BTW: Do those oak ties have any type of preservative in them? That will likely ruin the catalytic.
KevinB said:Where am I supposed to look re. cat glowing red? I mean, I know where the cat is...its hidden by the cover panel...I can look up there and see flames "floating" just below that panel is how I've been telling myself that the cat was working.
Rockey said:Whats the longest peice you can get in the firebox?
Chargerman said:A little update.
Just approaching 3 cords of walnut and elm this year burning 24/7. Managed to handle the -20 below temps a couple weeks ago and the -30 below wind chills from the last blizzard.
All is well in BBF land.![]()
BrowningBAR said:Chargerman said:A little update.
Do you have the second one installed in the basement, yet?
Todd said:Once you get that BBF installed in the basement with some insulation, I can see nice even heat throughout the whole house by burning both low and slow 24/7, maybe only reloading twice per day.
You may also get lucky and find the basement stove will handle most of the load for the whole house except colder days where you need to run both.
