CPM Airwash Question
KMinNH
24
Southern NH
I have a dumb question. Which way does the deflector go. I know the the two tabs go in the holes, but I'm not sure which way the curve in the deflector is supposed to go. I've had it both ways, but don't know which is right. Thank you.
The upper part goes straight up & parallel to the glass.
Ok. That's what I thought. When I put it in that way, it isn't quite parallel because it tips towards the glass and rests on the front walls of the firebox. Is that normal or should it stand up straight once the tabs are in the holes? Thank you again for your help.
