Cracked 8” thimble
11Bravo
18
Virginia
I have a home built in 1986. The 8” clay thimble (crock) runs through a block wall in the basement. My pellet stove crapped out and I’m going back to a wood stove. Upon inspection, the 8” clay thimble is cracked in numerous places but still intact. My wood stove has a 6” pipe system. I’m thinking I can insert a 6” clay thimble through the 8” thimble provided the 6” thimble O.D. is not too large. If it slips in, I could seal the annular space using a thin slurry of mortar.
Has anyone done this or have other suggestions?
kennyp2339
6,924
07462
insulated liner to a metal T snout then black pipe to the stove.
Reactions: EbS-P
11Bravo
18
Virginia
Thx Kenny. My chimney runs between the house and garage. Not sure I can connect the t snout to the pipe. No access except at the flue base inside, clean out. I do see snouts that can be installed with access through the thimble.
bholler
Chimney sweep
Staff member
Jan 14, 2014
31,958
central pa
All snouts are attached through the thimble.
bholler
Chimney sweep
Staff member
Jan 14, 2014
31,958
central pa
10-4. Never used one. So, would there be a need to seal the annular space between the two different pipe sizes? In other words, could stove gases flow through that gap?
No but you should seal it just to stop air flow.
bholler
Chimney sweep
Staff member
Jan 14, 2014
31,958
central pa
Thx. I’ll look at some vids. I’m still wondering if the 6” clay into the 8” clay is doable. I’m just a fan of masonry materials I guess.
Do you know what condition the clay liners are in? Does the chimney have the required clearances to combustibles?
11Bravo
18
Virginia
Chimney is solid. Old school masonry. Rectangular flue liners. I think the thimble cracking could have been a combo of heat and settling. It might be fine shoving an 8” pipe through then adapting with 6” to stove. The heat from the 8” through the cracked thimble might be nothing to worry about. Just trying to be safe as possible.
bholler
Chimney sweep
Staff member
Jan 14, 2014
31,958
central pa
So you are running a 6" stove into an exterior 8x12 clay lined chimney?? When was the last time the mortar joints between tiles were checked with a camera? Checked for cracks? Does the chimney have The required 1" clearance from the outside of the masonry structure to any combustible materials
11Bravo
18
Virginia
Yes. 6” stove pipe to 8x12. I realize this is not ideal for drafting but not uncommon. I’ve read the old train of thought was bigger is better. Now everything is 6”.
I’ve got a guy TVing the flue tomorrow. Based on my inspection it looks good.
The chimney is block with the clay liner. It travels up through the roof between the house and garage. Is this no longer acceptable construction?
vbu
Burning Hunk
Mar 3, 2019
211
MS
To be up to code all combustible materials need to have a 1" gap to the chimney if it's an exterior chimney
bholler
Chimney sweep
Staff member
Jan 14, 2014
31,958
central pa
It needed that clearance in 86 as well. What stove is this for?
begreen
Mooderator
Staff member
Nov 18, 2005
99,670
South Puget Sound, WA
Going from 6" to 8 x 12 is not a good combo for drafting or keeping creosote down.
11Bravo
18
Virginia
If it's internal it needs 2"
I’m in VA. Codes here are (and have been) strictly enforced. I’ll double check with the county inspector.
This is just a basic small stove used to knock the chill out of the basement. No more than a few hours a night. Very minimal use.
kborndale
618
LI
Even with light use, going from a 6" flue I to an 8x12 is most likely going to have poor draft and create a lot of creosote. A lot of creosote can lead to a chimney fire. This is when the clearance to combustibles becomes important as you don't want the chimney fire turning into a house fire. Most chimneys (especially older ones like you have) we're not built to code. Do yourself a favor and put an insulated SS liner in. The stove will burn better and cleaner and you don't have to worry about burning your house down.
kennyp2339
6,924
07462
Smaller stove, light use into a bigger chimney means you’ll more than likely be fighting the stove with draft issues rather than enjoy the occasional fire.
I recommended the insulated liner because a cracked crock (from settling or moisture) generally can mean other parts of the chimney are in the same boat, one piece doesn’t settle, the whole thing settles, and additional tiles can be cracked, or the age of the mortar between tiles can be compromised.
Reactions: kcmclellan
11Bravo
18
Virginia
Thx. Any recommendations on type, brand, etc.!
11Bravo
18
Virginia
Update 2/4/23
Chimney inspected and approved for use. Inspector Comments: Excellent workmanship, solid build, well-maintained in great condition.
Installed a U.S. Stoves EPA rated stove. 6” up through elbow to 8” increaser to thimble. Drafts very well. Super clean burn. Virtually zero detectable chimney smoke within minutes of start up. Hopefully this is the norm for this set up.
Thanks to everyone who took the time to provide advice and guidance.
bholler
Chimney sweep
Staff member
Jan 14, 2014
31,958
central pa
Did they check for clearances?
