So i had been contemplating this for the last couple of years. I got a couple quotes from some local companies 2 years ago and it was outrageous. 18000 bucks for a sump pump, crawlspace wall insulation, 20 mil liner, and a fancy entry door and a super duper dehumidifier and the hardware and labor of course. Also they were going to soda blast the whole crawl because of some black mold on the north rim joist that condenses in winter which is the whole reason for me doing this. I get that. Now mind you my furnace and pressure tanks are under my house which would have made it more difficult but 18000 is awful steep to me. So i priced the materials to do it myself. The liner was expensive....it was around 1500 dollars for enough 20 mil poly to cover the 1500ish sq ft foot print of the crawl but I wanted it thick enough and strong enough to walk on without damage. Had to buy butyl tape to hold the liner on the walls and piers and enough waterproof tape to seal seams which came ot to about 300. I bought a april aire dehumidifier for 1100. I dug and installed a sump basin and zoeller sump pump in my low spot. That was about 200 dollars. I dont have a groundwater problem but i wanted one in case of a water leak someday. I also pre drilled and screwed tapcons and fender washers in the liner every 16 inches where it terminates up the crawlspace wall. I installed the liner which was a chore by myself and a little help from my 10 year old daughter. Wrapping the piers was the worst part just because of the tedious cutting to make it fold around and look nice. One thing I didnt do is I didnt put insulation on the crawl wall simply because it is 80% underground and has never been a problem with condensation and I'm not trying to keep it from losing heat. I am waiting for more prolonged cold weather to see if the rim still condenses to decide if I should foam board or spray foam my rim joist. I'm hoping sealing the ground 100% with the liner, closing and sealing the vents, and the dehumidifier that maintains 55% humidity stops this from happening. As far as the mold....I just sprayed bleach liberally on the rim. I realize that isnt as good as soda blasting and that mold spores can easily spread through entire crawl and lay dormant but honestly it was one corner of the rim that it was visibly growing. I grew up in far worse and I think it will be fine and I just cant fork over that kind of cash.
Now that this is all done...I can say it is nice to not have to leave the vents open in the winter. I know, I know....you think I have it backwards. But if I kept my vents closed before during winter the rim condensed terribly. Leaving them open let drier air in and helped to some degree but not enough. It also made my floors cold as hell lol.
So I woke up this morning and walked to the kitchen. It got down to 40 last night so i wanted to see the difference it made with the vents sealed up. Toasty baby. I can finally walk barefoot again. Also the house dropped only 1 degree last night after the stove burned out whereas before it would have been reload time. If I have no problems with condensation on my rim after this winter I imagine I will go ahead and insulate it which should make a big difference in a colder temps.
So far im around 3500 in on this but I'm glad I finally did it.
Sorry for the long post but thought I should mention this here in case anyone else contemplated it.
