Crazy but is it a Cool AES Maintenance kit for Magnum Country Flame? (Ash Cleanout) Has anyone seen
Don2222
9,246
Salem NH
Hello
Just came across this! Reminds me of the Leaf Blower trick for the venting!! I heard this kit sells for $190.00 !!
(broken link removed to http://www.americanenergysystems.com/Stock/LibraryFiles/t-0066techbmf3645maintenancekitfurnacecs1.pdf)
I bet anyone could make one for their stove!! Using wood would be easier to fabricate!!
Then hookup a shop vac and a compressor and all clean!! NO MESS NO FUSS!!!
This really seems kinda cool if it works?? Any comments?
AES Technical Bulletin
MF3645 Maintenance Kit
Product models covered: Countryside 3500 Series, MagnuM 6500/7500 Furnaces
Topic: This technical bulletin will be addressing the MF3645 Maintenance Kit, cleanout door, how
to install the door and how to clean the appliance with the door.
Tools needed: Rubber mallet.
Procedure:
♦ Take the door off the appliance. Sometimes a rubber mallet is needed to tap on the bottom of
the door to lift it up.
♦ Install the cleanout door on the appliance. Line the cleanout door up to the hinge pins and
press down on the door to install it on the appliance (see picture #2).
♦ Close door and attach ash vac to tube as shown in picture #3.
♦ The first time you use the kit, drill ¼†hole in pipe caps.
♦ Insert air nozzle tube into appliance bending tube as needed.
♦ Turn ash vac on and blow air through the nozzle bending tube as needed to insure tubes have
been cleaned.
♦ Move tube to other pipe cap and repeat process.
  • [Hearth.com] Crazy but is it a Cool AES Maintenance kit for Magnum Country Flame? (Ash Cleanout) Has anyone seen
Hello
Does anyone have any comments on this???
Meh, leafblower works great and I don't hafta fab up nothing.
Does the leaf blower get the pellet dust out of the fire box like this does?
Pellet dust out of the fire box? Is that ash?
If so, not completely.
Im not impressed either.
Leaf blower is cheaper and actually cleans the stove. This requires much more effort... Not a fan.
I an think of a few reasons as to why this is a bad idea.
1. You cannot see what you are doing
2. You are positively pressurizing the stove which will send fly into areas where it shouldn't be, such as the air intake, igniter carriage and air flow switch
3. You physically have to install a new door so you risk the chance of damaging the one you need
While this is great way to clean out the heat exchanger... you could simply open the ash pan door drop in your vac line and with the same flexible air hose and compressor, blast it all out. I do it all of the time.
For all of you who think the leaf blower is the be all end all...it doesn't work as good as you think it does on all stoves.
Good points that come from alot of experience!!
Leaf blower seems to work great for the inseason cleanings. It doesnt take place of the deep clean at the end of each season.
