hounddog said:shame on me, i do have a cap but it is not installed yet , my question in return is , and im not experienced with this but , why would the cap help.. its not snowing or raining , so the moisture is coming else where....... yes it is a pre epa stove pos but the wood is seasoned..
BeGreen said:What size is the flue pipe? Is this a masonry chimney?
!! it will help not only keep weather out , but it helps hold a little heat in the top of the flue. moisture (believe it or not) is a byproduct of combustion, one of the cardinal rules of chimney health is to maintain a temperature above 220 degrees or higher all the way to the top. this keeps moisture in a gassious state (steam) if flue temps drop below 212 degrees the moisture (water) will revert to a liquid state and collect on the flue walls,then it will run down collecting soot as it goes, now as it drips down , it will revert back to steam, this is evaporation which is a cooling function this cools the flue further which increases the effect. this in extreme conditions can cause "cold chimney inversion" or downdrafting in some cases and will cause tarlike creosote to build rapidly. older units which do not "reburn" "smoke" will put more of this soot that the moisture mixes with in a chimney faster, especially when a stove is dampered down. you will definately want to get the flue swept, and we need to figure out where the moisture is coming from soon, as the tar creo is the most suceptable type to chimney fires. im not reallly trying to scare you , but its a serious issue and needs to be addressed promptly.I am no expert but would think that no gasket on your clean out door could very well be your problem. the thing with draft is it doesn't care if it comes from your stove or your clean out door and the air has moisture in it. I would install the cap and seal the door it cannot hurt and it might fix the problemhounddog said:sorry i forgot to mention , the clean out door, is a metal hinged door with no gasket or seal on it.
hounddog said:my chimney is masonry block , with a clay reddish -orange insert, the only tar like creosote is near where the stove pipe goes into the chimney and on down to the clean out door , its not caked on , you can just see it here and there where it ran down .cleaned chimney , at start of season. and nothing was in chimney all the way down to the stove pipe entrance. one question with the chimney cap,? is it gonna change the way my stove drafts? this stove was in my house when we bought it a yr ago... just waiting for money to update stove , is there a place that sells newer type epa stoves? i thank you all for your help,.
crazy_dan said:I am no expert but would think that no gasket on your clean out door could very well be your problem. the thing with draft is it doesn't care if it comes from your stove or your clean out door and the air has moisture in it. I would install the cap and seal the door it cannot hurt and it might fix the problemhounddog said:sorry i forgot to mention , the clean out door, is a metal hinged door with no gasket or seal on it.
Jim Walsh said:Wrap the door tightly with 1-2 layers of Saran Wrap, lay down a thick bead of silicone on the flange and close the door. Once the silicone has set up just remove the saran wrap.
