creosote build up
cyclone
161
North East Pennsylvania
What are some tips and suggestions to reduce cresote build up from start up of your stove and to the next refill of your stove.
Yes, I know dry wood!!!!!!!!
Stove temp?????
Ideally you'd like to see a minimum stove temp of 350 or so. 500-600 is ideal during the cold months though.
Burning the stove hotter when the wood is first put in - this is when the temp of the firebox and stack is usually greatly lowered.....to burn off the moisture in the wood...and then ignite the gases. If a stove has to be turned down low, it is always best done during the later stages of the fire - the charcoal stages.
