Hi all - not much of a poster but I certainly spend a lot of time on this site.
Looking for some opinions - today I noticed a lot of very light, thin, brown Creostoe flakes exiting my chimney, they're paper thin & easliy turn to dust / ash if you rub them between your fingers. At first I wasn't too concerned but after looking up @ the roof & yard around the house there are quite a few of them - we have snow on the ground & roof now so they're very noticable.
Burning seasoned Ash in a FPX 36 elite (CAT unit), approx. 25' of insulated pipe going through center of house (in a chase), through attic then through roof. I had just run the unit charring a new load (didn't over fire but ran in Bypass mode for a bit longer than usual) engaged CAT & went outside shortly after - this is when I noticed the flakes. Chimney was swept this Fall & I always get her going good & hot before engaing CAT & wait for the CAT to get glowing before shutting down the air.
Has anyone seen this before & would you have the chimney swept now or did I just take care of that unitentionally??? LOL. Third year burning unit & never noticed this before. Obviously from the "dryness" & "light consistency" of the flakes I'm burning clean but never had a buildup that blew out the chimney before so not sure if I need to clean again or if this is not a concern. As mentioned I have it cleaned each year & I'm burning about the same amount of wood (maybe a bit more) than the previous two years.
Thanks all for your input & opinions
