OK, instead of doing deeper cleanings mid-season, I figure clean it now (and, if I burn enough, a second cleaning in January) on the Accentra insert. And for once, I was quickly able to remove the flat heavy panels that flank the "medallion, and not get hung up getting them past the flared ends of the burn pot -- I need to think through how I did that, for the future.
Now, perhaps my short-term memory is failing me here, and perhaps it's always this way, but -- once I had the inner heavy panels out and the removable panel at the bottom and the cover for the combustion fan, in the interior I am seeing some black, grease creosote-like stickiness back there, and around where the bolt & lever retain the cover for the combustion fan. Normal? Perhaps it has been that way all along and I never noticed it. It scraped off readily enough. Now, one thing I did last season that was different was, based on a recommendation here, I sprayed creosote remover around the end of the auger tube at the end of the weekly light cleanings to help with hard buildup there -- and I think that seems to help. But, is creosote redepositing in the rearmost parts of the stove area? Seems like activity inside the stove should be rather "dry". Still using Hardwood Heat pellets by Hamer, no change there.
