Has anyone got a clue as to what is causing this stain on my chase? It's not rust and seems to be a change in color of the paint on the metal. Any feedback would be greatly appreciated. Jeff
It's not rust when you get up close and look. Galvanized metal is intact and not rusting. This appliance burns only wood. Yes, I have confirmed the metal crown was painted. Thanks.Certainly looks like rust. Why can it not be rust?
Does the appliance hooked to this stove burn wood only? Coal? Pellets? Other?
Are you certain that metal crown had paint on it to start?
![[Hearth.com] Creosote/oxidized paint stains form wood burning fireplace [Hearth.com] Creosote/oxidized paint stains form wood burning fireplace](https://www.hearth.com/talk/data/attachments/134/134429-6c284d1d33d606be982a729e1a5fa35e.jpg?hash=bChNHTPWBr)
Thats rust!!
![[Hearth.com] Creosote/oxidized paint stains form wood burning fireplace [Hearth.com] Creosote/oxidized paint stains form wood burning fireplace](https://www.hearth.com/talk/data/attachments/134/134461-78bd73b26f11ac47222441a18c72420d.jpg?hash=eL1zsm8RrE)
Yeah that rust is because the galvy gave up from the heat and left the building and rain took over. Not the wood. I ain't buying any "cap fire". They start a lot farther down than there.
Also, with that cap having such tight (too tight for my taste) mesh on it; I'd be very surprised if there would be a build-up issue without the operator knowing it was going on, since that sucker would be clogged tight..
@Maysa , how much accumulation are you getting out of that chimney when you sweep? Any draft issues from that cap clogging up? Smoke in the house from stove not wanting to draft well? If everything is normal and without incident, I'm guessing that cap was just a lemon. Know the brand? Try contacting them directly?
If it had been stainless or aluminum that would not happen. Even my psi ted cheap steel terracotta cap has not done anywhere close to that in 3 yrs.
How tall is your chimney? Seems like your getting a lot of consensus.g moisture on your cap as it may be cool from a long run. And are you sure your not burning wood with a MC 25% or higher say closer to 30%?
.. on the freshly exposed face of resplit wood, not on the end grain.Moisture content can be measured by a moisture meter...
Cap fires are pretty common. They can have a small fire in them without the flue catching fire. It's not uncommon at all, and the result is burned off galvanizing. Just like the one picture.Yeah that rust is because the galvy gave up from the heat and left the building and rain took over. Not the wood. I ain't buying any "cap fire". They start a lot farther down than there.
