It's a standard size piston, otherwise it would be stamped . 010 , .020, etc , if it had been bored oversize at anytime.... Seafoam sprayed on carbon and left to sit overnight will loosen things up..try not to gouge anything .. soft wire brush.. I was good with a razor blade, hold it very flat and go easy... Watch you don't dig the gasket surface as well.Ok written on the top of the piston std 205 04 13a this mean anything to anybody?
Mabey it was the oil,modern oil is different than the old stuff,mabey it dosn't like some of the additives.That would make since. Everything was fine when I put it up. Change the oil and problems started. The governor is just pop over and over.
Scrape away what you can, sea foam des work to loosen the stubborn stuff. It's not critical to get it perfectly clean. Only the gasket surface has to be spotless.What's the best way to clean the piston and vaulve carbon deposits?
I run state of the art synthetic oil in some 50 year old equipment. If its been taken care of to this point, it will not create issues now.Mabey it was the oil,modern oil is different than the old stuff,mabey it dosn't like some of the additives.
Brake fluid also can work wonders for loosening stuff up.
Sent from my iToilet using Wipetalk2
Like your nice paint job?
Works the best on all that pesky paint they have on cars nowadays.Brake fluid also can work wonders for loosening stuff up.
How about cleaning the valves seats? Any good tips here? There is a carbon build up on that lip.
Yikes... tread carefully, there!
If solvent and a rag doesn't work, I guess I'd be trying lapping compounds, testing with the least aggressive first.
Applying by hand?
I'd wait for MasterMech answer this, since I'm just a hobbyist, but I'd worry about the actual valve seat being clean, not the area around it. So, if there's crap actually on the valve seat, preventing the valve from sealing, and assuming you don't need to re-cut the seats, I'd be lapping the valve in place. That means applying some lapping compound, and using the little suction cup tool to lap (doesn't take much!). You can clean the flat tops of the valves with a razor blade, and clean the stems the same way (very carefully!), but keep the razor away from the seats.
