We are nearly done installing our wood stove. Our set up is in the basement, goes out the basement wall (which is above grade), and then up the side of the house. The only thing we have to figure out now is how to cut through the gable end of our house, but in such a way that isn't going to cause leaks.
Our gable is exactly 12" wide, and our Selkirk chimney pipe is 10" in diameter (6" pipe inside). We need to maintain a minimum 2" clearance to combustibles. I found this post on how someone "notched" out their overhang because they had the same issue I have. But does anyone have a suggestion on a tutorial on *how* to do something like this? We have no idea how to handle the shingles, membrane, fascia, etc and make sure it's all sealed up properly and prevent leaks. We're considering hiring a contractor for this if we need to, but we're trying to save the cash. From the ground up to the gable, it's about 15 feet.
This is our setup outside so far (obviously not finished or in use; we put the rain cap on to keep the rain out for now).
![[Hearth.com] Cutting Through Gable End for Chimney Pipe [Hearth.com] Cutting Through Gable End for Chimney Pipe](https://www.hearth.com/talk/data/attachments/250/250193-410b200d00ed6b10d5fe8f96ee50fad1.jpg?hash=aZ8fWaB9L_)
![[Hearth.com] Cutting Through Gable End for Chimney Pipe [Hearth.com] Cutting Through Gable End for Chimney Pipe](https://www.hearth.com/talk/data/attachments/250/250194-a651fd17c945e84627b0a0ca262ff099.jpg?hash=Ro1RZE-m4e)
