D-vent versus B-vent with heat-recovery ventillator
cyberiad
10
central coast, California
Some B-vent gas fireplaces seem to have high specified efficiency. An example would be, some ads for Monessen say their B-vent units' efficiency is "up to 80%".
I understand the B-vent will create negative pressure and draw cold air in the house, so high efficiency can be a bit of a joke, depending. But maybe a heat-recovery ventillator could equalize the pressure and pre-heat the incoming air?
Bottom line is I want the occasional option of opening the fireplace doors, if that's reasonable and practical.
any extra air circulation system can potentially mess up a bvent stove in a tight house... I have found folks with system like that often have a problem with the spill switch tripping because of the negative pressure holding low exhaust rates in the spill hood.
<>Bottom line is I want the occasional option of opening the fireplace doors, if that's reasonable and practical.<>
You can open the doors on a Direct Vent or a B-Vent, but for aesthetic purposes only.
There will STILL be a piece of tempered or pyroceram behind the doors.
Both are sealed combustion chambers.
The difference is how that combustion air gets in...
