Damper needs to be added to ultrablack adjustable pipe
rideau
2,167
southern ontario
I'm going to have to add a damper to my stovepipe in the off season. Have an adjustable ultrablack pipe, which I believe is 36 inches sliding inside 36 inches. Same pipe that I used for my Fireview, rear flue, now recommissioned for my Progress Hybrid top vent. With the top vent, I only have a little over 14 inches of pipe below the sliding joint. Have a probe thermometer mounted just below the joint. The pipe section with damper I believe is 4 inches in exerior (exposed) length. Where does it get installed in relation to stove/adjustable pipe?
Double wall right? I have this pipe, an adjustable section and in a box, the damper section you describe. The short damper section I have is an appliance adapter. It is suppposed to be mounted to the stove. I don't know that they make a damper section that is intended to be placed anywhere else. Good idea on a damper for the PH.
Thank you.
With my cast iron hearthstone flue collar, the appliance adapter/damper section from simpson did not fit. It was too loose and was unusable. I was able to use it with my BK which uses a steel collar. Before you spend the money, about 35$, on the damper section I would verify with other owners or with woodstock that an appliance adapter will work with the PH's cast collar.
The ultrablack by ICC recomends that the damper be placed 18"-24" above the stove if i remeber right and in your case the easiest would be to put it at the top if you can reach it
Double wall pipe. This should be ICC part # UBD
(broken link removed to http://www.icc-rsf.com/main.php?t=chem_produits&i=37&l=en)
[Hearth.com] Damper needs to be added to ultrablack adjustable pipe
Ohhhh, gotcha! Thanks for correcting. Said like Gilda Radner: "Never mind!" :)
It comes from ICC in a short length (4 inches?) which I figure I'll install at the top of my adjustable, which will shorten the adjustable pipe by 4 inches....
It would have to go in a fixed section or the adjustable wouldn't be very adjustable!
Both the top and bottom of the adjustable have about 3 or 4 inches of "un-adjustable" pipe that could easily accept a damper. I might do just that, so I can close it down when I'm not burning the stove...
