data logger
in hot water
895
SW Missouri
this is the data logger that comes with the solar control I showed in another post. Plug it into a USB port and slip the SD card into it. Now you can program the control parameters. Then take the card to the control, plug it in and it transfer the set up data. The control does come pre-programed with 5 or so arrangements. You cannot build new arr. but you can change setting within them.
Then the card records the system data as it runs. Here are a couple screen shots of the set up screen and the view screen. When you put the cursor over any point on any line it reads the temperature and time of day.
This control also accepts input from the Grundfos flow and temperature sensors.
I know the manufacturer of this control and have been testing a few versions for them. They are looking for dealers or distributors. I suspect street price could be under $300 depending on dealer markup.
  • [Hearth.com] data logger
Cool. Memory has gotten cheap. I use a 2GB SD card in the NoFossil Control System. It records all inputs, outputs, and internal variables every minute for a whole year. Then it rolls over and starts overwriting the previous year's data a day at a time so that you always have the previous 365 days worth. Pretty amazing for a $10 card.
Looks like a nice unit - is the software on it cross platform capable, or are customers going to have to run a [del]Microsoft[/del] defective box just to make use of it?
(I get annoyed by all the manufacturer supplied software out there that won't run right on my Linux box - I really don't like running virused malware systems)
Gooserider
Anyone with experience as to this data logger?
Pico USB TC-08 8-Channel Thermocouple Data Logger
Pico
Pico
Not sure how much experience you have with computers/programming but for ~$105 you could get:
1 - Arduino Board
1 - Arduino Ethernet Shield
8 - OneWire Temperature Sensors
This setup like that Pico would require a computer except if you went the Arduino route you would could just setup a PHP script to pipe the readings into a MySQL database. Another benefit of going with the Arduino is that you have 16 digital pins that would allow you the ability to control your system in the future.
Years ago I did quite a bit of programming, so maybe it's time to start again. Thanks for the info.
If I go the Arduino route, is there a shield to record data rather than using a computer, and then downloading to the computer? I'm really new at the jargon for this, but I think you get the drift: an Arduino with a data logger.
They have shields with SD card interfaces on them but you're still going to need a program to view the data (i.e. write to CSV file and graph/view it with Excel).
Personally, if you have a computer in your home that is always on already then I would go the ethernet shield route. The reason being that the data is automatically logged and if you want to view it you could just fire up a web browser and have JPGraph & PHP graph the results.
Next month I'll be working on setting up my Arduino controller with an ethernet shield and the corresponding MySQL database and webserver so if you need any help I'll be more than happy to share my code and database.
Gooserider said:
Looks like a nice unit - is the software on it cross platform capable, or are customers going to have to run a [del]Mac[/del] [del]School Toy[/del] defective box just to make use of it?
Gooserider
True True
Twofer, I was just wondering if you were going to do a detailed write-up of your control system. It's a slick system and I love to learn more about it.
It's nothing fancy but here is the thread about my control system. If there's any details missing that you're interested in feel free to ask.
https://www.hearth.com/talk/threads/44038/
I'm thinking of excuses in addition to boiler monitor/control to get an Arduino, etc. and learn the programming. After reviewing some sample sketches, the language structure is very similar to dBase programming I did years ago, so it shouldn't be too difficult to learn. So, what other "useful" uses to do with Arduino -- maybe a robot to split and stack boiler wood?
go to sparkfun.com and look down the list of sensors. That should give you an idea or two.
I am also ready to hook up my arduino board. I have it working with 4 sensors and one relay on a prototype board now. I have been building out the mysql code and the graphing portion. I am using an opens ource tool called pentaho, it's way overkill for this but we develop with it for work so I am getting up to speed and making something for the house. If you strip away all the junk I would point some of the members here to the openflashchart php modules. VERY clean charts for that sexy professional look.
I can post any of the stuff out here as well. I am using a perl script I wrote years ago to log tty data , it is in production at many companies for years , very reliable code. The arduino sends out formatted lines that are simple to parse and I have decided to update the ttylogger to convert the formatted lines to sql inset statements written to a file every 1-5 min. Very simple and requires no special modules to work, all you need is the basic perl and mysql. I'll have the script make the insert file and run it to load in the data.
It's about 3/4 baked right now. I have a sample database schema called temperature with about 5 or 6 tables. The ttylog code is done about another hour to add in the SQL statements. Pentaho is up and a VERY simple dashboard is drawing a graph against the "RAW" temperature table. I was looking to wire it in this weekend and start logging real temps.
It's a nice project I have been itching to do and I'm having fun with it !
You're much more advanced in programming than I am. I have a "goals" list that is designed in part to cover my aging process. Although I'm only 62, I know the time will come when scaling Mt Everest no longer will be achievable, so I have on my list re-learning programming. C++ was the language at the time I did the goals list, but when the time arrives, who knows? Maybe start now with the Arduino and get a jump start on future dementia, although my wife thinks I'm demented already.
The last couple days have had me thinking about how it might be a worthwhile project for one of us to setup a database and webserver that could do the logging and graphing for people. This way those that are not familiar or comfortable working with PHP/MySQL could just setup the Arduino to send the sensor data there. This would also eliminate the need for everyone to maintain a local webserver, not that it is hard to do with XAMPP.
What do you guys think?
ETA: The one hurdle would be the authentication of the incoming data from the Arduino's but I think this could be overcome with a lightweight AES implementation.
I would agree that a "readymade" setup for the code, with simple and clear instructions, would be excellent. I am very comfortable and competent when it comes to the hardware of boards, sensors, interfaces etc. but I have not coded for years. Any help you could provide would be worthwhile.
Some thoughts I had:
Any needed applications should be open source and free, available as a download.
Most of us can find a PC or two (I have two now) to reformat and load with just the setup needed to make this run. What are the bare necessities for applications required? Which OS?
In my case, I would like to have the arduino controller run independently of a PC, with only the data logging and conversion functions running on the PC.
Additionally, which make/version of Linux will be best for someone like me who is new to the OS? I want to get at least one PC reformatted and running soon, as I have ordered the arduino board and sensors.
JeBatty: Maybe this will work:
Little boy, I have some candy for you ... A nice little arduino sketch that reads temperature sensors and turns on relays ....
Code:
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
#define TEMPERATURE_PRECISION 9
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire;);
// arrays to hold device addresses
uint8_t SourceFeedSen[8], SourceReturnSen[8];
uint8_t LoadFeedSen[8], LoadReturnSen[8];
uint8_t StoreMaxSen[8], StoreMinSen[8];
uint8_t TempSen1[8], TempSen2[8];
// Try for an array of pointers to the arrays so wa can process them in for loops
uint8_t *SensorList[6];
// Save the Relay pin setup
int relay1Pin = 7;
int relay1State = LOW;
int lastrelay1State = LOW;
// Counter in Seconds
long relay1Sec = 0;
// Relay/Pump will not cycle more than once every xx seconds
long resetinterval = 180;
long collectinterval = 60000; // get temps every nn000 milliseconds
// Set up some default temperature variables
float DeltaTdropF = 5; // Buffer temp for comparisons
float FloorTempF = 120;
float SenAdj = 4;
// Setup some handy temp variables
// Farenhieght
float SourceFeedTempF, SourceReturnTempF, LastSourceFeedTempF, LastSourceReturnTempF;
float LoadFeedTempF,  LoadReturnTempF, LastLoadFeedTempF,  LastLoadReturnTempF;
float StoreMaxTempF,  StoreMinTempF, LastStoreMaxTempF,  LastStoreMinTempF;
// Set up some handy loop counters and general variables.
float ver = 2.0;
int j,k;
int sennum;
// Some format flags to control what prints
int logSourceFeed = HIGH;
int logSourceReturn = HIGH;
int logLoadFeed = HIGH;
int logLoadReturn = HIGH;
int logStoreMax = LOW;
int logStoreMin = LOW;
void setup(void)
  // Fill in sensor list with named var addresses
  SensorList[0] = SourceFeedSen;
  SensorList[1] = SourceReturnSen;
  SensorList[2] = LoadFeedSen;
  SensorList[3] = LoadReturnSen;
  SensorList[4] = StoreMaxSen;
  SensorList[5] = StoreMinSen;
  // start serial port
  Serial.begin(115200);
  Serial.println(" ");
  delay(15000);
  Serial.print("Gassification Bioler Temperature IC Control Version ");
  Serial.println(ver);
  // initialize the relay digital pin as an output:
  pinMode(relay1Pin, OUTPUT);
  pinMode(ONE_WIRE_BUS, INPUT);
  // Start up the library
  sensors.begin();
  // locate devices on the bus
  Serial.print("Locating devices...");
  Serial.print("Found ");
  sennum = sensors.getDeviceCount();
  Serial.print(sennum, DEC);
  Serial.println(" devices.");
  delay(5000);
  // report parasite power requirements
  Serial.print("Parasite power is: ");
  if (sensors.isParasitePowerMode()) Serial.println("ON");
  else Serial.println("OFF");
  // assign address manually.
  SourceFeedSen = { 0x28, 0x54, 0xD6, 0x5E, 0x2, 0x0, 0x0, 0xAC };
  SourceReturnSen   = { 0x28, 0x7C, 0x2, 0x5F, 0x2, 0x0, 0x0, 0x75 };
  LoadFeedSen = { 0x28, 0xC9, 0xD6, 0x5E, 0x2, 0x0, 0x0, 0x57 };
  LoadReturnSen   = { 0x28, 0xF9, 0xCB, 0x5E, 0x2, 0x0, 0x0, 0x2A };
  // set the resolution to 9 bit
  for ( j = 0; j < sennum; j++)
    sensors.setResolution(SensorList[j], 9);
  // Make sure we are starting with relay off
  digitalWrite(relay1Pin, LOW);    // set the Relay off
  // Initialize the state vars
  relay1State = LOW;
  relay1Sec = millis()/1000; // Set the initial relay last switched time to the startup time
// function to print a device address
void printAddress(uint8_t deviceAddress[])
  for (uint8_t i = 0; i < 8; i++)
    Serial.print(deviceAddress[i], HEX);
    if (i < 7) Serial.print(" ");
// function to print the temperature for a device
void printTemperature(uint8_t deviceAddress[])
  // method 2 - faster
  float tempC = sensors.getTempC(deviceAddress);
  Serial.print("Temp C: ");
  Serial.print(tempC);
  Serial.print(" Temp F: ");
  Serial.print(DallasTemperature::toFahrenheit(tempC));
// function to print a device's resolution
void printResolution(uint8_t deviceAddress[])
  Serial.print("Resolution: ");
  Serial.print(sensors.getResolution(deviceAddress));
  Serial.println();
// main function to print information about a device
void printData(uint8_t deviceAddress[])
  Serial.print("Device Address: ");
  printAddress(deviceAddress);
  Serial.print(" ");
  printTemperature(deviceAddress);
  Serial.println();
The rest ...
Code:
void loop(void)
  // call sensors.requestTemperatures() to issue a global temperature
     sensors.requestTemperatures();
  // print the device information
    printData(SensorList[j]);
// Ok now actually do something to control the EKO
// Fill in my vars for easy reading
 SourceFeedTempF = sensors.getTempF(SourceFeedSen);
 SourceReturnTempF = sensors.getTempF(SourceReturnSen);
 LoadFeedTempF = sensors.getTempF(LoadFeedSen);
 LoadReturnTempF = sensors.getTempF(LoadReturnSen);
 StoreMaxTempF = sensors.getTempF(StoreMaxSen);
 StoreMinTempF = sensors.getTempF(StoreMinSen);
 // Save the state before the Checking starts
 lastrelay1State = relay1State;
// if ( (SourceFeedTempF + DeltaTdropF) > LoadFeedTempF )
if ( (SourceFeedTempF ) > LoadFeedTempF + DeltaTdropF )
 { // Turn on Tank pump flag
   relay1State = HIGH;
 } else
 { // Turn off Tank pump flag
   relay1State = LOW;
 if ( SourceReturnTempF <= FloorTempF )
   relay1State = LOW;
 // Now set the relay -- After all the logic so we only turn on/off once
 if (((millis()/1000) - relay1Sec > resetinterval) && ( relay1State == HIGH ) && ( lastrelay1State != relay1State ))
   Serial.print("Setting Relay pin HIGH Run Sec: ");
   Serial.println((millis()/1000)- relay1Sec,DEC);
   digitalWrite(relay1Pin, HIGH);   // set the Relay on
   relay1Sec = millis()/1000; // Using seconds to store longer interval 10-12 hour run times
 } else if (( relay1State == LOW ) && ( lastrelay1State != relay1State ))
    Serial.print("Setting Relay pin LOW Run Sec: ");
// Store the values for the next run
LastSourceFeedTempF = SourceFeedTempF; LastSourceReturnTempF = SourceReturnTempF;
LastLoadFeedTempF = LoadFeedTempF; LastLoadReturnTempF = LoadReturnTempF;
LastStoreMaxTempF = StoreMaxTempF; LastStoreMinTempF = StoreMinTempF;
if ( logSourceFeed == HIGH )
{  // create an EASY to parse line for database inserts
   Serial.print("log:SourceFeed:F:");
   Serial.println(SourceFeedTempF );
 // Don't loop like crazy the Temps rise and fall SLOW !
 delay(collectinterval);
} // End of main loop
Last, A picture of the test setup.
That should kick start anyone wanting to try this. The program and wiring in the picture are all working.
( My son and I did the picture to take to school )
Note on the code: I hacked up a lot of the code originally to get the size down to a postable size --it didn't work. If someone wants to share how to post the text files ( I was rejected ) I will gladly put up the original and the ttylog script as well. The sketch IS functional, I removed comments, duplicate sections for each sensor etc.
Maybe we should pull this discussion into a dedicated Arduino thread.
Why do that? I can't be the only one to enjoy listening to conversations in languages I don't speak a word of. It's just fun imagining what you might be saying!
MWK -- Thanks, much -- I'm not moving too fast on anything right now except completing some doll wardrobe cabinets for two of my granddaughters. But I'm starting to get myself intrigued by something that likely will turn into lots of fun, plus soak up my winter time in the frozen north country. Thanks again.
I am far from a Linux guru, and do not know if the following will work for the purpose being discussed, but I've had a little experience with a version known as "Ubuntu"- which has the dual advantages of being available at no charge, and also being usable by way of a graphical user interface (click on icons, etc.) for those of us who aren't I.T. whizzes. Google around and you can probably find more about it quickly.
