electrathon
Cleaned mine Sunday. First time with a soot eater. WAY better and easier than a brush. I got little creosote, a lot of fly ash.
I just did mine today - After our first year burning with a Super 27 (approx 15' straight up double walled pipe) and I got about 1 cup of black powder with the odd small flake of soot / creosote. Would you guys say that I was 'burning properly' last year? - I thought 1 cup was decent - my Husband was surprised we 'had so much'
Thats what it takes me from start to a clean stove to do my 24' chimney. It's an involved setup. I put a ladder on the roof and remove the top section.
Question to the soot eater guys. Are you using it bottom up through the stove? How do you control the soot coming down the chimney as your cleaning?
My sweep was here Monday. I wasn’t home, but my son said that he used a Soot Eater and was done in 20 minutes.
He charged me $182. I think I will buy the equipment and do it myself from now on.
I've always been concerned about knocking the cap off by accident. I have a high chimney with a steep pitch roof and wouldn't be able to get up there to put it back on, if I were to knock it off. Is it easy to tell when you reach the top when using your Soot Eater?I think it's a little over $50 off Amazon. Very easy to use, even for a rookie wood burner!
I clean my stove 2 times a year. And almost always end up with about 3-4 gallons of creosote from a 30’ masonry chimney with a wood stove hooked up to it. Still trying to get the kinks worked out of my system.
If it is 3-4 gallons per sweep, it is very much and would be worried. I guess the liner is not insulated. I wonder what the cruising temp is during winter time.
Considering the OP has an NC-30 I assumed he has a liner. Maybe that was naive to thinks so.There's possibly not a liner, which is why that much creosote is there in the first place.
There is a clay liner. Also I’m in the process of having the chimney lined with insulated pipe, thinking that will help too. I was going to replace my stove this fall because it’s oversized but after talking to the manufacturer I decided to try a few things they suggested first. But that’s for another thread.
I think after making the changes I did then I’ll probably be making less creosote. Also the chimney just would not come clean when we bought the house so I have been running some of the creosote chemicals to try to get some of the really hard stuff to loosen up and I think that’s contributing to it. I use a spot eater and brush both fwiw.
