- Sep 18, 2012
- 47
I have a 55-TRP22 and have been problems getting a clean burn.  I am burning Somersets.  I will totally clean my stove and it will burn clean for 8 to 10 hours.  Then, the burn pot will start filling up and soon the window is covered by a layer of black soot.  I have played around with the settings on the unit, trying additional air (raising LBA) as well as lowering the feed level.  What I have found is if I drop the feed rate below 5, the flame goes out.   So, I have tried running it on a setting of 5-5-1 with a heat setting of 1 and blower setting of 3.  I have raised the LBA as high as 9 with no discernible difference.
I've called tech support twice. The first time, they had me make some tweaks to the feed settings. Said I might need a control board. The second time, they said that a dirty burn is an airflow problem and to check gaskets etc. or it might be a pellet problem. Since I've got the Somersets, I figured, there's no way its the pellets. I checked gaskets by doing the dollar bill test on the door. Used a lighter to see if there was any leaks that would pull the flame around the windows or the hopper lid. I checked to make sure the hopper latches were tight. Everything seemed to check out right. So, on a whim, I decided to try a different pellet. I had a couple of bags of McFeeters. So, I stopped the stove once the pellets were just about gone, cleaned it really well. And started running the McFeeters through it.
What a difference. First, I found that the McFeeters were a larger pellet. Seems like there of a larger diameter. But, they also seem to be longer pellets as well on average than the Somersets. And so, while I'm not sure if the size was the issue, it seems like they fed MUCH slower than the Somersets. And, so for two days, burning the McFeeters not only did the burn pot not fill up. But, the glass only got a slightly yellowish hue to it. But, very faint. And I could see through it the whole time. So, this morning, I loaded up with the Somersets. By the time I got home, the hopper was almost empty, burn pot is full, and the window is covered with soot.
Anyone have any thoughts?
(BTW, it doesn't seem to me that the McFeeters put out the BTU's that the Somersets do. But, they smell good. REALLY REALLY good.)
