I'm working on a wood stove install in my basement. The plan is to put the stove in a corner, and build a 1.5" air-gap wall with steel studs, faced with concrete board (dura rock). After that, I was thinking about building a wall agains the dura rock out of limestone (from the hills around me) and mortar. Because of height restrictions, the floor was going to be limestone tile (~1/2")
Stove is a modest Drolet (El Dorado?)
So, questions:
(1) How thick does the limestone wall need to be to be an effective heat storage medium. ~4" thick is easy to source.
(2) To be effective, I remember that there needs to be air holes at the bottom and top of the air gap - ho many and what area should they have?
(3) If I just lay the tile under the floor with thinset, I'm worried that (a) they'll be connected to the floor, which is always near 55F, and (b) that temperature gradients might make them crack out of the mortar. Has anyone tried building some sort of insulation in under the hearth or laying a slab of mortar cut with vermiculite under the hearth surface? Unfortunately the room height is 86" and the required floor-ceiling clearance is 84", so I can't build a substantially raised hearth.
So, questions:
Not sure why I could remember it now? All I could come up with last night was rock wool??
