Do chimneys expand vertically?
Bryce250
2
Canada
When I was resealing the storm collar on my steel chimney recently, I noticed that it was held to the roof flashing with 2 screws. I was wondering, do chimneys expand vertically when they heat up? If so, should the storm collar be able to move upward w the chimney? Maybe those 2 screws shouldn’t be there. Thanks for your input.
begreen
Mooderator
Staff member
Nov 18, 2005
99,743
South Puget Sound, WA
Normally the storm collar is not screwed. It is held in place with a bead of good-quality silicone.
Reactions: cahaak and Bryce250
semipro
4,271
SW Virginia
Steel expands in all directions when heated but you'd notice it the most along the longest dimension.
It's easy to calculate if you know the temp change. I think you'd get pretty close if you used the average temp over the length of pipe.
Reactions: Bryce250
gthomas785
865
Central MA
The screws also defeat the purpose of the storm collar by creating a leak point. I'd take them out and replace the storm collar.
Reactions: Bryce250
