Leelli said:If you can't afford the additional foil you can ask Cesar Chavez. He has a bleeding heart for those in need of heat ; )
!ansehnlich1 said:I am absolutely furious at you guys for makin' fun of this poor dude's setup. You all ain't as smart as you think.....that is NOT his stove, it's his SEPTIC SYSTEM!
northwinds said:That won't work. No viewing window.
stoveguy2esw said:pipe's probably leaking smoke due to no underneath air and the fire is smouldering easy fix first check behind the stove make sure the wall surface is sturdy enough, now load your pistol and aim about 6 inches above the bottom of the stove and...
