Does my chimney need cleaning?
Budman93
11
West Virginia
I'm curious if you guys think I should have this cleaned before using it this winter. I had it swept and inspected when we bought the house in early 2024. Last year was my first winter with this stove in this house. I tried to burn it very hot regularly to keep it cleaner. I don't think it looks too bad but I'm a novice so idk.
[Hearth.com] Does my chimney need cleaning?
Reactions: Whitenuckler
Your chimney looks similar to mine after a season of burning hard, it needs to be cleaned. I use a Soot Eater and it works very well on my 6" stainless. Kudos on the hot and clean burning BTW.
Had to Google the soot eater. Looks like a weedwhacker for a chimney sort of. I would need to make nearly a 90 degree bend to get it through the stove. Is that possible with these? I'm also curious about how much of a mess it makes inside.
I'm not exactly sure on the chimney height but I think it's about 30 feet. The roof is super steep so no chance of me doing anything from the top.
The Soot Eater rods are flexible, but will most likely not go through a 90 degree angle, I think you'll need to remove it. Like you, my roof is steep, so I do all my cleaning from the bottom. A short section of my chimney runs from the stove top to the chimney support, (about 6ft), it contains (2) 45 degree elbows. I remove that section and clean it outside, using the SE from each end. For the main run, I take a plastic pail and drill a hole in the center of the bottom that just a little bigger than the connectors on the rod. I run the rod through that and place the pail over my chimney pipe, to catch the majority of the soot. It will be a little messy, but it's not awful. Just install additional sections as you go up and remove them as you bring it down. My wife usually takes a shop vac, and puts suction by the hole in the pail to catch dust etc. What you'll end up with is a dry powdery substance that looks similar to coffee grounds. I hope this helps!
PS - the SE is good for 24' I did have to buy additional rods to get to the top of mine.
Reactions: Turbo89
Yeah it looks like I would need to disconnect the pipe and maybe slide the stove over. looks like it would be cheaper to just buy 2 kits to get the length instead of one and 4 extra extension rods
A soot eater has no problem going thru a 90. I go thru my thimble which is a 90 with either rods but the white ones are easier as they are more flexible.
