Annual chimney and wood stove maintenance
mvortex1
14
Valley Forge
I live in SE PA, burn lots of Ash (SMH) after losing 20 of them. Cherry too. I use very dry heartwood of white pine to start and burn off creosote on a routine basis. My clean out cap is in a fireplace, brushed from the top, approx 20 feet on a medium pitch roof. Over the past few years, I've been hiring the wood stove installer to come out and do an annual maintenance. This last time however, I'm not so sure they even swept the chimney. I'm about to go up and do it myself, just to make sure it was done right, also I need to seal my chimney cap (turbo seal). Just wondering if anyone had a less than stellar experience with this type of service. The reason why I'm concerned is basically after inspecting the wood stove after they left, I put my hand inside the connecting pipe out of the back of the wood stove and basically scooped up nearly a cup of soot with very little effort. The day after we spent hours wiping down the entire area of the hearth, shelves and antique wheel lamps and everything else on display around the fireplace area which I've never seen before. Of course it was good to have an excuse to rip everything apart and clean like it should be, but there was a fine black dust on everything after they left. Wondering if I'm being too picky? If I would have done this myself, everything from top to bottom would have been entirely clean.
Yes, I’ve had a similar experience, where the overpriced sweep / installer tried to upsell me. Since then I bought a soot buster and clean my stoves from the inside.
I can see my chimney cap from the ground to tell if it’s dirty / clogged and to make sure the soot buster gets all the way out of the chimney.
In your case I’d make them come back if it was still dirty and moving forward I’d buy a soot buster and do it myself.
I've always swept my SS chimney myself. Not a high roof but this spring at 78 y/o was my last time. The dealer offers to clean it for $160 if done on Thurs or Fri before June 30. Seems like a lot for a pretty simple job but...you know the ground looks further and further away!
Reactions: Turbo89
For half the price of one cleaning you can get a soot eater and keep cleaning your own chimney with never going on the roof again.
Reactions: Turbo89
Here is a video. I bought another cheap version for cleaning dryer ducts to use on my pellet stove.
Reactions: Turbo89
Agreed about DIY sweeping if you can do. Some chimney sweeps are great, some are complete hacks and everything in between. At the least I wouldn’t hire the same company again.
Reactions: kborndale
What do you mean by “burn off creosote on a routine basis”?
I have that same question for the OP. I know that a lot of “old timers” talk about doing this but it’s a bad idea and there should be no need if you are burning dry wood. Just a sweeping annually to brush out the fine soot.
He’s probably referring to the creosote remover powder. You toss a scoop on and burn hot for a while. You can’t use this stuff in catalytic stoves, but I’ve used it on my older Jotul for years. My sweeps always present minimal soot.
Sorry, just saw this. I keep bone dry cedar and white pine handy and run the stove temp up higher than usual, then ease it back down until it's embers. I then open up the clean out and let it go cold. After that I run the nylon brush through and get about a half gallon jug worth of light fluffy powder.
I wound up building a platform out of a heavy wooden pallet for my tractor front end loader forks that I can just drive right up to my roof line. I then climb up a step ladder and jump on that, no more worries it makes it way easier to just walk up the slope and clean the chimney and come back down without worrying about sliding right off the edge. I'll be doing it myself from now on since I got a pretty lousy attitude from the manager of the fireplace location. Thanks all
So you are talking about burning creosote off the inside of your stove or your flue? If you are cleaning your flue by having chimney fires that's certainly an interesting way to do it.
