Hello,
I'm based in Perth Australia. We've found a lovely wood burning stove to place in our existing fireplace - Parkay Aspect 8. R 0.18 required.
Unfortunately I cant find any tradespeople interested in construction/installation so I'm going to have to DIY it.
The stove will fit entirely in existing brick chimney with concrete and brick footing. The hearth however will need to come out across floorboards that are supported with joists.
My plan was to use compressed sheeting to bring the floorboards level then use a skamtoec 225 to achieve the r value with stone on top. I was planning to use the skamotec and stone in two pieces with butt join (sealant) to compensate for any movement for the timber vs the brick chimney.
Just wondering if anyone had any other suggestions or whether this sounds reasonable ?
Thanks for any input
![[Hearth.com] Hearth pad construction - challenging ! [Hearth.com] Hearth pad construction - challenging !](https://www.hearth.com/talk/data/attachments/350/350679-b58650b25d7d995967a2b96fc673142e.jpg?hash=YcWrXbaQ_0)
