Restoration chances on a 1826 home with a ‘three sided fireplace’?
restoration_hopeful
5
Maine, USA
Sorry, it’s my first post so I’m not totally sure everything you’ll need to know and what’s not necessary, so info overload incoming!
I own an 1826 home in Midcoast Maine as of just under 2 weeks ago (yay!) that heats on oil (way less yay given prices). Here’s the real issue: There’s a chimney that may or may not support(*explained p5) the foundation smack in the middle of the house that used to have a ‘three-way fireplace’. Air quotes because the previous owners’ children (it was an estate) had conflicting opinions on what that meant. Either it was a single, massive hearth that fed up into a single chimney and had three fireplace openings in a T-shape, it was a double-sided fireplace with the offshoot third just feeding into the same chimney, or it was three separate fireplaces that just fed into the same chimney. They were all sure their version was the right one, of course.
I have no official records, and I haven’t found anything online suggesting one version would’ve been typical for the area or period. I have a masonry guy coming for an inspection whenever he has an opening (there’s not a whole lot of urgency up here, so it could be today or two weeks from now), but I thought I’d seek out some outside opinions in the meantime.
In a perfect world, I’d really love to have it opened back into a two-way fireplace with a wood stove or insert (I’d prefer a stove since my whole family has wood stoves and it’s what I’m used to, but I’m open to more experienced opinions!) set in it to maximise heat distribution through the ground floor. The double side of the T both have wood stove thimbles that were primary heat with oil as secondary until some time in the 1990s, when they transitioned to oil primary, and then at some point after 2000 (the best the owner’s children could give me), the wood stoves stopped being used and were eventually removed. All along the ceilings in the living room and what I’m using as a bedroom (but they used as a formal family room) are little vents with damper levers that go into the rooms upstairs presumably to help spread the heat evenly or block it off so it stayed warmer on the ground floor.
One foundation wall was still the original dry-stacked stone and had significant bowing, which, combined with not enough support columns, put some pressure on things toward the right side of the house (outside of the slope, the only damage we’ve found is some minor cracking in the beehive and hearths since brick and stone have less give than wood planks) and there were dry-stacked walls in the middle of the crawlspace around the chimney area holding up two original oak beams. The inspector recommended I have a masonry specialist in to to confirm structural integrity before purchase since the chimney is supporting the middle of the house(*next sentences are why I’m uncertain about this). The masonry guy I have coming whenever he does is the one who did that look for me. The inspector thought the old oak beams under the chimney were rotting and causing the chimney to sink which is what caused the foundation wall to buckle in a little, but the masonry guy said while they were rotting, it wasn’t a chimney issue since they weren’t actually supporting the chimney anymore. Whoever did it was just just too lazy to put rebuild the stacks at some point around the 50s or 60s, by his guess, when they knocked out two of the old walls that held up the chimney (the missing dry stacks perpendicular to the remaining two in the middle of the crawlspace) and built the chimney up to the house from the ground to meet more modern standards, though he didn’t look inside (this was just for the estimate so I could negotiate the price down) so we don’t know if they did any work on the masonry up through the ground floor and upstairs. I’ve already had guys come in and address the foundation wall and put more supports in (and I have an 8’ drop off my side door to prove it until they re-bury the new foundation wall) so that’s that sorted, which maybe means the chimney is no longer a supporting structure? Not totally clear on that part, but to me, it seems that if the issue is that the chimney didn’t used to touch the ground so the dry stacks that held it up also held the middle of the house up, and then the chimney was build down to the ground but didn’t hold the weight anyway, then the chimney isn’t more supportive than any other individual support is.
So I guess the question(s?) I’m asking is if we pretend the chimney inspection above-ground is going to come back totally fine and without issues and the furnace is vented elsewhere and all that jazz, would it be totally crazy and stupidly expensive to reopen the two-way fireplace? Would opening just one side be any better? Should I accept that an in-room unit is just the most reasonable option? And, of course, if there’s anything else in the post that screams at you, please let me know that too because I probably haven’t realised it’s important.
I’ve attached a picture of a good chunk of the floor plan of the ground floor. It’s not quite to scale, but it’s close. The hopefully-straight-through bricked-over areas both measure 48” tall x 62.5” wide, and both sides have a grey marble hearth that extends 24” out. The little closet-looking thing next to the offshoot fireplace is a beehive for baking.
Please let me know if there’s any more info or clarificstion you need to form an opinion!
  • [Hearth.com] Restoration chances on a 1826 home with a ‘three sided fireplace’?
This setup sounds quite complicated. If it were me, I’d be hiring a structural engineer to answer questions about structural integrity. After that, I’d hired a reputable chimney sweep to talk about how to proceed with what you can do with the unit overall safely.
I'm a little confused. Are you saying you want a two-way open fireplace, or two stoves? Or two inserts?
You may already know this but two-way fireplaces tend to perform poorly. Because of the huge amount of opening area, you need a lot of draft to prevent smoke rollout which means whatever heat is projected from the fire will be more than canceled out by the draft. This is the case for single fire places as well, but it's much more noticeable with multi-sided fireplaces. Combine that with the fact that the heat of the fire is being spread over a larger space so you're not getting the radiant heat off the rear firebrick that you would from a single fireplace and the experience tends to be really underwhelming.
If the existing chimney is large enough, you could fit two liners side by side and hook up two stoves. No problem with that. Just remember, two wood stoves means twice the work to keep them going. If I were in your shoes I think I'd figure out which space I wanted to spend the most time in, put a stove there, and work on designing the airflow to distribute heat from that location.
Reactions: restoration_hopeful
If the chimney moves, or fails, what happens to the rest of the house?
Can the rotten floor beams be repaired and still support the house? It sounds like they were at one time attached to the chimney… a firm no for that method now. I’d think the chimney is the last thing to consider on the list, unless it is to remove the chimney so you can fix the house, and then build it back again.
As to the historical fireplaces, since they were marginal room heaters, I bet they were only used when the room was being used. I’d bet they were originally separate fireplaces. Your original house was probably added on many times over the centuries. Figure out the original floor plan and the additions and you’ll discover the original chimney configuration.
I think I found your house on Zillow. Are you in Thomaston? From the aerial view it's pretty clear that your chimney has 4 flues, so the fireplaces were almost certainly separate. Should be easy to install liners and get a stove or two in there.
It's very unlikely that the house is supporting any part of the chimney, more likely the opposite.
I am! That's amazing to know, thanks so much! Definitely a relief to know there are multiple flues (condition notwithstanding) while I wait
The chimney isn't an issue for support anymore due to the supports being put in the crawlspace. The chimney used to be supported by the four dry-stacked walls that held up the two beams which held up the chimney, but the chimney now supports itself. The support issue was that instead of putting to-code supports in when they redid the chimney to not be held up by the stacks, they just left 2/4 stacks knocked out, which caused some settling
This is awesome to know! The additions stick off the side of the house, so the original little rectangle with the three faces were present either from the jump, or at least without an addition being put in place to add it. Someone else mentioned the different flues being visible on aerial view, so I'm very on board with it having been three separate fireplaces!
Thanks so much for taking the time to pose those questions and explain a little of the historical uses! It's easy to get twisted up when trying to research on my own, especially since it's my first place and I want to do things right, so having some well-informed folks agreeing is a huge weight off my shoulders
As far as what I wanted, I was mostly wicked confused because of the two estate heirs both being adamant that their interpretation of 'three-way fireplace' was accurate. I want to restore it to a reasonably accurate state without compromising on efficiency and modern comfort, so I definitely fell down a rabbit hole trying to figure out the three fireplace situation which, of course, spiraled off into how about how it's prohibitively expensive to open a fireplace up unless it's reopening, but even then the examples are almost always on an external wall and not dead center of the house!
I'm definitely not planning an open fireplace if I'm able to reopen it, but rather an insert or getting a wood stove and a block-off plate (my preference) set in it. Someone else found an aerial view that shows four flues, which makes sense since there are the three faces plus another long-defunct fireplace upstairs, so that's a huge weight off my back. The chimney is...sizeable, clearly. The previous owner did have two wood stoves with the two thimbles left in place after their removal, but like you said, that's twice the work. One is definitely no problem, but I think two would be a pretty big investment in not only time and effort but also in money since it's just me and my dog in the house right now.
I was for sure spinning out a little with all the online 'look what I did to restore my old house!' blog posts and videos, so this had brought me safely back down to earth. With a little luck, I'll be able to ask the masonry expert about the feasibility (and price!) of just reopening one side of the fireplace, or whether it would be better to just keep the thimble and set it in the room proper. I definitely plan to see if a little grease will get the damper levers on the ceiling ground floor/floor upstairs moving smoothly again so I can adjust the distribution accordingly! Thanks so much!!
Yeah, it's definitely not my easiest project! Thankfully, some other commenters are very confident in it being separate flues plus just the very low odds of it being a three-way fireplace originally, so that's a huge weight off my shoulders! One I put there myself, admittedly, but a weight lifted nonetheless. I'm hoping that since there are proper supports in the crawlspace so the remaining dry stacks that used to support the chimney are now just a statement piece left because removing the beams would be tricky, it won't be an issue to just open one side back up and buy me the depth of it to scoot the wood stove out of the room proper. Of course, everything depends on that inspection, but I'll for sure be asking the masonry guy if a structural engineer is something he recommends and if he's worked with someone who works the shoulder season, since a lot of folks cut their hours way back once it starts getting cooler
Check with the town for records on additions, etc. they probably have some permit records.
