I do have a good knowledge of metal, as all the above said it appears normal from the pic.Just looks like a Fisher burned like most folks burned in Fishers. Hot. Not a smart way to burn but they could take it. No warping in evidence but I would put a straight edge on the sides to check for it.
BrotherBart hit the nail on the head, only thing I can add is, Do the doors close correctly? If they do, your in business. If she was over heated things would warp as they cooled, the top may crown a bit and pull the sides in. The doors would be either off alignment or a good gap. Cleaner up, some paint, good as new![]()
sometimes in the construction of the stove, one of the pieces that make up the legs may have been cut a tad to short or to long, not a worry it happens, I had a stove that had three different size legs. easy fix for someone who has a grinder you may know, a local weld shop can fix that right upbut the stove rocks a little on the floor. It could be the floor?
I don't want a Fisher stove but I sure remember some good times in Amarillo. And some dang cold times too.
Lubbock boy here way back when.
Do a good six inch safe chimney and if you later want a different stove you can just swap it out. The ole Fisher will toss a lot of heat but eat a lot of wood. Which there ain't a lot of around the Panhandle. Now only if you could burn wind in a stove...![]()
My ace on in hole is the unlimited free hard wood from the cabinet shop.
But, if you are looking for 24/7 heating, and you work away from home, a modern stove will give you longer and also cleaner burns.
The double door fishers were not as great on burn times as the single door units.
pen
The stove is priced at $350, I'd want to heat/warm up my shop for 8 hours a day, 2-3 days a week. Would I be shoveling in wood all day with the fisher?
2400 sq ft with a dividing wall down the center, so 1200 sq ft fully insulated.At that price, and for those requirements, assuming the space is appropriate for the stove (how big is the area, much insulation?) I think this could work very well for you.
pen
The Fisher will do just fine in my opinion. Now, I don't own a new stove, I do have a friend who does, "vermont castings" Yes the fisher will chew up some wood but it'll blast you out if you want it tooI'd want to heat/warm up my shop for 8 hours a day, 2-3 days a week. Would I be shoveling in wood all day with the fisher?
